% Oxygen Required for Corrosion
I'm wondering if anyone has a good handle on how much (or how little) oxygen we would require in the following scenario to avoid corrsion of our uncoated carbon steel pipeline:
Fluid - sea water
Temp - 5 to 25 degrees C
Velocity in pipe - 1.4 m/s
Pressure - as high as 2000 kPa, as low as atmospheric
We're installing a de-aeration unit to prevent corrosion, but have no idea what level of oxygen is acceptable to avoid major corrosion.
Thanks!
Jordan
www.soltech.ca
RE: % Oxygen Required for Corrosion
Any O2 will corrode.  I'm not familiar with any equation that you could feed your data into and get an answer like 1.07 mils/year.  I've run brine dearators and we pulled about 20" Hg to 25" Hgand didn't have any corrosion problems.  I'd just plan on having a system to inject O2 scavenger chemicals based on corrosimeters or test coupons.
