changing reference in drawing
  This is probably a very simple question, but I can't seem to figure it out.  How can I switch the file that a drawing is in reference to?  Meaning, leave all the annotations and dimensioning, but change the model.  I know how to do it with a different configuration.
RE: changing reference in drawing
When opening the dwg/assy, there should be a box for references.
Chris
SolidWorks 07 3.0/PDMWorks 07
AutoCAD 06
ctopher's home (updated 03-26-07)
i tried using that and it changed the new model to the one from the previous drawing
Did you pick the wrong model?
Chris
AutoCAD 06
im trying to import a new model into an existing drawing.  when i use the references button it converts the new model to the old one.
ok I got it.  It's not when I save as, but when i open the document for the second time that it works. thanks
