Nitrogen Blanketing of totes with agitators
I need to install a nigrogen blanketing system on a process using 10 stationary totes.  3 of these totes have agitation.  Is there a mechanical or magnetic seal I can use to seal around the shaft?  The unagitated totes are obviously not a problem, but I'm having trouble engineering around these shafts....
RE: Nitrogen Blanketing of totes with agitators
Here is one that we use on staionary and portable blenders for dry powders and plastics. I would give them a call to see if they have a seal to cover your situation.
http://www.mecoseal.com/index.php
