Motor connections to my VERSAMAX PLC
can somebody help me with the motor connections to this PLC.I am trying to develop a STAR start DELTA run mechanism that will be controlled by this PLC.I am done with the software but i have no idea how to go about wiring this PLC with the MOTOR.PLEASE help
RE: Motor connections to my VERSAMAX PLC
Is this a joke?
yeah its a joke!!..seems you didnt get it!
and for others who got it please suggest!
We are having trouble with the fact that you've "finished the software" for something you seem not to understand in the first place..  You know, "garbage in Garbage out"?  So it would help if you could describe more about your task as we're kinda confused.
Keith Cress
hi keith..
             wat I mean is that i've developed the ladder logic diagram for the star delta connection.
now i want to drive a relays through the PLC output, which in turn would control the motor connections.
This PLC has nine 2A internal relay outputs..can you let me known wat this might mean? i mean does it mean that PLC outputs will be able to source 2A?
Depending on which VersaMax relay output module you have the answer is yes, BUT the common can only handle a maximum of 4 Amps. So if you put a 2 Amp load on each of the outputs and turn them all on at the same time you will blow a fuse.
thanks
     another problem i have is abt the analog inputs to the PLC. suppose i give an analog input to the
PLC.the PLC's A/D converter coverts it into a digital value and this value is stored in a register in the program. wat i want to know is how to use this value from the register to make comparisons.
Please suggest
