print in 1 minute 10 seconds
use wildfire 3 to print to the plotter- no problem.
convert to pdf & print to the HP1280 no problem.
normal print to the HP1280 & wait 1 minute 10 seconds.
any ideas on how to reduce this wait?
RE: print in 1 minute 10 seconds
Usually, when processing a print, if two lines are on top of each other, pro-e will only print one line. This config option will cause pro-e to print both lines. It reduces time a ton because it is quicker for the printer to double print lines than for pro-e to determine that only one is needed. I'm not sure how this config option works with PC's, but I'm sure it is similar. For my prints when I apply this option it brings printing time down to 25 ins from 45 mins so it is significant. (P.S. that is with a Blade by the way, LOL, I'm working on the assembly from hell.)
WHAT I SHOULD OF MENTIONED IS THAT DURING THE 1 MIN 10 SEC THE PROGRAM IS UNRESPONSIVE- ONLY THE PRINT COFIGURATION WINDOW IS SHOWN.
Hope this helps Texaspete.
