airfoil surface
airfoil surface
hi there
i'm working on an imported airfoil surface in igs format.the surface curvature is somehow discontinous.i want to modify the surface to obtain a smooth surface preserving the original design.
i have tried to obtain several intersection curves using planes intersecting the surface, modifying the resulting curve using simplify curv,and finally lofting between intersection curves but the result is still unsatisfactory.
please help
thanks
please help
thanks
RE: airfoil surface
Make sure your Image quality is up to, otherwise it will make the surface look more squared.
Scott Baugh, CSWP![[pc2] pc2](https://www.tipmaster.com/images/pc2.gif)
www.scottjbaugh.com
FAQ731-376
RE: airfoil surface
If you use the Fit Spline feature, you have control as to how tight the spline will "stick" to your under-lying sketch segments. A tighter spline will have smaller minimum radii and be less "rounded", but more accurately represent the segments beneath. The opposite is true for a more loose fit.
Jeff Mowry
www.industrialdesignhaus.com
Reason trumps all. And awe transcends reason.
RE: airfoil surface
Jason
UG NX2.02.2 on Win2000 SP3
UG NX4.01.0 on Win2000 SP3
SolidWorks 2007 SP2.2 on WinXP SP2
RE: airfoil surface
RE: airfoil surface
The other option, if its a surfaces, fix it up and knit them up to create a body, if its an imported body...just create planes at different points and use the section view to section at the plane, create sketches on those planes and convert the sketch entities.
RE: airfoil surface
http:/
Autodesk Inventor Certified Expert
Certified SolidWorks Professional
RE: airfoil surface
hope that helps
-L@P.I.D.
Work: Dell PW690-Intel Xeon E5345 2.33GHz-PNY QUADRO FX3450 Drivers 77.56-4GB DDR2 FB-DIMM 667MHz ECC-80GB 10K-250GB 7.2K-Win XPx64-SW2007 SP2.2-RHINO 4.0 SP0
Play: Intel X6800 Core 2 Extreme - Asus P5W64 WS Pro i975X -2GB Corsair XMS-EVGA NV7900GTO(Mod. GTX Bios , FW93.71)-74GB Raptor-250GB WD Caviar
