variable pattern
variable pattern
variable pattern
I am hoping to pattern a feature that directly proportionally (linearally) reduces in size as the pattern advances across a straight line sketch.  What is the best way to make this happen?  Should I define the original feature's dimensions using equations? Thanks,ProEdj
RE: variable pattern
Check out the Vary Sketch option in the Linear Pattern.
When setting Direction 1 make sure to select the driving dimension.
The Help section has good step-by-step details.
cheers
SW07-SP3
And sk?tch of you feature must be fully defined!!
Sketch Driven Pattern.
Ken
