Configurations in assembly
We made an assembly of a transport link with parts created in the assembly. We have several configurations.
problem1:
* We've made an assembly of the transport link with 2 supports.
* But when we change the configuration of the transport link (TransportLink with Supports.asm), we don't get a good image on the screen.
* So we have to open the TransportLink.asm and choose the same configuration.
* And only then we get the view that it should be.
problem2:
* We want to make an overview of the different configurations in an other assembly.
* We want to insert 5 times the same tranport link assembly , but each time in an other configuration.
* When we change one configuration the others change too.
problem1:
problem2:
RE: Configurations in assembly
Poor screen resolution or the configuration not appearing as it should.
Using a Design Table to control configurations usually creates more stable configurations with less "surprises".
SW07-SP3
I'm not exactly clear what you mean in the other questions about a good image.
Jeff Mowry
www.industrialdesignhaus.com
Reason trumps all. And awe transcends reason.
--> the configuration not appearing as it should.
We are Using a Design Table to control configurations
SW07-SP3
In problem 2, are the link assys patterned or 5 separate instances?
Which version of SW?
How big are the assemblies?
Can you post here for download and review? (See FAQ559-1177 for details)
SW07-SP3
yes
pattern, but when we insert 5 separate we have also the problem
2007 3.0
+- 10.000 kb
i am trying to make a site where i can post pictures
But for posting images see FAQ559-1100.
SW07-SP3
Scott Baugh, CSWP![[pc2] pc2](https://www.tipmaster.com/images/pc2.gif)
www.scottjbaugh.com
FAQ731-376
