Remove Body from CATPart in a drawing view?
I have a CATPart with 2 bodies. I want to create a drawing view with only one of the bodies active (Shown). How is this done.
RE: Remove Body from CATPart in a drawing view?
If you already have a view, while in drafting select the view and go to edit modify links and switch to the 3d part, then select the body you want, then switch back to drafting and choose "add all." then update.
That's a very poor way to work. It's unacceptable in most any respectable design department. Aside from that, it's not practical, as deactivating a part simply for a drawing, means that you also don't get to use it anywhere else. Unless, of course, you choose not to update your drawing, which is an equally poor solution.
The best way to overcome this problem, appears to be to use assembly structure, instead of multi-body parts, so that you have the Overload Properties available. I do realize that this is not an option for everyone, but it solves the problem instantly. Even if you choose to use fixed constraints on all your parts, (while positioning in assembly coordinates) it would be better than this multi-part body mess...
Catia Design|Catia Design News|Catia V5 blog
Forever Young
I haven't used layering in V5. Is this an option (with filters) for Multi-PartBodies? Anyone?
I would like to use filters/layers in V5 but you really have to define the methodology first. And we have some many files without layers now...
And multi-use partnumber is our solution.
Forever Young
For springs and other flexible parts, we make different CATParts, but store them in PM with different suffix (PN1234-3D1, PN1234-3D2, PN1234-3D3, etc)
We try to avoid multi-body parts, but one of our exceptions is molded parts with inserts. I just designed a plastic fan that has a metal hub. Another exception is over-overmolded plastic/rubber housings.
