How to create Dart between the two surfaces with given dimensions
I am trying to create darts by using bead command but everytime when I am going to create/pick the point where I want to create dart I am getting error that point is not a part of surface.
Is anyone can help me out for how to create dart.
I already created two surface as a part of the drawing but I am not able to put dart pl. help me
thanks
thanks
RE: How to create Dart between the two surfaces with given dimensions
1. (this depends on how the point is created) Edit the point to add the surface as the support
2. (if you can't do #1) Project the point onto the surface and use the projection as the start of the dart
