pipe thickness
pipe thickness
Is there a website or link I can get the steel pipe's thickness? for example, I found for the 114.3mm OD pipe, the thickness can be 4.8mm, can be 3.2mm. I ever searched one website: h ttp://www. traceappli cations.co m/charts/P ipe_Dimens ions_and_W eights.htm
But it shows that there is no such thickness for 4" pipe, Why?
RE: pipe thickness
Joe Tank
RE: pipe thickness
http://www.engineersedge.com/pipe_schedules.htm
RE: pipe thickness
These tables are attached to ASTM pipe specifications as an appendix. They list nominal outside diameter and nominal wall. You need to read specifications to find the outside diameter tolerance. The minimum wall for almost all pipe is 12.5% less than the nominal.
Ask any of your pipe distributors, they will send you a pipe table with their name on the top of it.
Rust never sleeps
Neither should your protection
http://www.trent-tube.com/contact/Tech_Assist.cfm
RE: pipe thickness
you can find useful information in TC PINPING hand book its named the bible of piping
