ListBox with Checks
ListBox with Checks
ListBox with Checks
Hello all
I have a listbox on my form with Liststyle set to fmListStyleOption and MultiSelect set to fmMultiSelectMulti.
I am trying to select the first item in the list thru code but it doesn't seem to do anything.
I am using:
CODE
ListBoxUserSelect.Selected(0) = True
from the help file
Quote:
object.Selected(index) [= Boolean]
The Selected property is useful when users can make multiple selections. You can use this property to determine the selected rows in a multi-select list box. You can also use this property to select or deselect rows in a list from code.
Anyone have any ides on how to get this to work.
RE: ListBox with Checks
DanLan,
Have you tried posting this question in the Visual Basic forum in Eng-Tips or Tek-Tips?
SA
