Manufacturer of DN50, PN40 trunnion mounted Ball Valves ?
I need a few DN50, PN40 (European norm is a requirement) flanged trunnion mounted ball valves, preferably all stainless, but steel body is also accepted. (For coming projects also same in DN50 to DN100, and PN16 to PN64.) I have found a couple of possible suppliers, but the problem is deliverytime and weight, as trunnion mounted tend to be 'special items' for higher pressure classes adapted to requirements.
Anyone knowing of more 'regular' suppliers ???? Note: must be trunnion mounted, not floating ball!
RE: Manufacturer of DN50, PN40 trunnion mounted Ball Valves ?
You might try Sud Robinetterie Industrie (www.sri.fr). Excellent valves, excellent supplier. The fact that they're French is just a bonus. I've used the BF (2 piece floating) and A / W (3 piece trunnion) mainly flanged ANSI but they have DIN as well.
Documentation is no problem, delivery was on time and everybody was happy.
http://www.mokveld.com/
Take a look.
"Do not worry about your problems with mathematics, I assure you mine are far greater."
Albert Einstein
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
Couple Italian suppliers I use:
www.pibiviesse.it
www.abvvalves.com
If you need faster...
www.mwvalves.com
Andy
Albert Einstein
Italian will not be fast (16 week minimum (and considering it is only 16 weeks or so until their August shutdown, count on longer)). But, good quality, well documented product.
Andy
www.lntvalves.com
Cut and paste this URL for the sales contacts from the website.
h
