Attaching Photos to drawing
Hi
I am trying to apply photographs to a drawing to send by email. I am using Autocad 2000 and have put the photos on the drawing by insert/raster and put them on paperspace and it all prints out great. When I send the drawing off by email the drawing opens up and there is just the space where they should be with the path specified in the rectangle. Do I have to send the photos as seperate files
or is there a way to link them like an xref? or permanently attach them.
Any advice would be most welcome
Cadman
RE: Attaching Photos to drawing
yes, you do have to send the photos with the .dwg
file -> e-transmit
this will create *.zip file with all attached photos plus drawing and extras
experiment with e-transmit
hope this helps
Intel P4 3.0 GHZ
512 DDRAM
Win 2000 Pro
Autocad 14, 2002 with EP 2.3.1
If I understand you, you are sending a .dwg file?  Is the person opening the file using a full version of AutoCAD or an LT version?  LT versions will not open pictures at all since 2002.  I've built drawings with included pictures and e-mailed them successfully several times.  When in doubt that the recepient might have LT I generally also send a .pdf file.
David
