AISC 13th Edition and 2000 IBC
If I am providing calculations on steel connections for a project governed by the 2000 IBC, is it acceptable to use the AISC 13th edition? I believe the AISC LRFD 3rd edition is referenced in the 2000 IBC.
Val
Val
RE: AISC 13th Edition and 2000 IBC
If you're designing under the IBC 2000, then the 3rd LRFD is the specification to design with. If you want to use the 13th edition, at the very least you'd need the blessing of whoever's reviewing/approving the connection design calculations.
Don Phillips
http://worthingtonengineering.com
Val
