Dimensions (Show/Erase v's Manually Added)
Hopefully this is a simple one, but is there a congig option (or drawing.dtl) that would allow dimensions that are Show/Erase in origin to be a different colour from manually added dims in drawing mode?
Cheers
Kevin Hammond
Mechanical Design Engineer
Derbyshire, UK
RE: Dimensions (Show/Erase v's Manually Added)
no
-Hora
Simple
Kevin Hammond
Derbyshire, UK
I usually create two layers one for model dims and one for drafting dims so that I know which ones I can change to modify the model. You can then hide one layer and select all the other dimensions and change the Text Style color in the Properties dialog box.
I also usually create a layer called dims_current for the dimensions that I want to keep on the drawing which is a mix of model and drawing dims which helps if you accidentally show a bunch of dimensions and undo doesn't work. It's also usefull when you show dimensions using the model tree which won't give you a preview before throwing all dimensions on to your drawing.
DIMS_MODEL Layer Rule Name = d*
DIMS_DRW   Layer Rule Name ~= d*
Michael
