Will Autocad 14 work in Win XP Pro?
Can Autocad 14 be installed and run in Windows XP Pro? My Win ME crashed for the last time, now I want to install XP Pro but I need to know if it will work with Autocad 14.
cupcars
cupcars
RE: Will Autocad 14 work in Win XP Pro?
You will find a variety of opinions re AutoCAD and XP in Thread555-14976
As a side issue, I have gone back to using Windows ME as I found XP to be possibly the worst operating system I have ever used. You may also consider upgrading your CAD package as I think AutoCAD r14 is no longer supported by Autodesk. The problem with AutoCAD is that it is still essentially a DOS program with a windows interface rather than a pure windows based program. I know that later versions 2000i etc are compatible with XP.
