analytical field
analytical field
analytical field
I trying to apply a pressure on a small section of specimen in the middle and this load is distributed according to an expression in term of position.
Should I write the expression a cording to the real x-y-z or abaqus treat the start of the small section as (0,0,0).
Please help me
RE: analytical field
You can do either, but the second method you propose is more intuitive (and easier to read) - just make sure you create a locla coordinate system and then reference this in the analytical expression you write.
thanks, brep
how could I create a local coordinate system.
Menu->Tools->Datum->
Set Type to CSYS.....etc.
