Can you make BOM # and part# the same?
I was wondering if there is an easy way to force the catia BOM number to match the partnumber, short of writing a script to do it?
RE: Can you make BOM # and part# the same?
which field in the bom are you trying to match?
I want to match the catia generated number for ballooning and the PartNumber that appears in the tree.
That is script material, but why do you want to rename parts???  I would not recommend renaming parts,  if you work in cache mode you can lose links to other parts.
Derek
Just wondering for my boss's sake, thanks
In drafting you can balloon with partnumber...
Tools / Options / Drafting // Annotations and Dress Up :
Balloon Creation Associativity with : Numbering / Part Number / Instance Name
Eric N.
Thanks itsmyjob, that is the solution I was lookihng for.
