Negetive Eign Value
Negetive Eign Value
My beam model worked fine for a small load. However, whenever I was trying to give a large load, its giving me an warning massege "2 negative eign values" and followed by an error message. I am sure the load is not too much for the model. Any one have any idea whats going on and how I can avoid that problem.
RE: Negetive Eign Value
Or you would like to try using stabilization in the step to check is if there is an error in the model such as material.
What is the error message that you get?
Martin
Yes, I Set Nlgeom to on.I think that is why the beam is distorting too much.
And turning The NLGEOM On is a must in large deformation analysis in order to get the correct result.
Martin
try adding *controls after your *step. It helps with my solution sometimes.
*Controls, parameters=field, field=displacement
, 100.0
