BOM to Excel 2003 problem
For some reason Catia is outputing blank BOM's in excel. I can save .txt's and html's no problem, but .xls comes out empty. I am running Windows x64 and Office 2003. Is there some setting I am overlooking? Is it a 64bit incompatibility? My coworker can output a BOM into excel without any problem on his 32 bit machine. Any help will be greatly appreciated.
RE: BOM to Excel 2003 problem
Teabags - I use R16SP5 and R17SP2 on a Dell64.  I access excel all the time for design tables, but I had to have a SP for Excel to work correctly.  Sorry I am not at the office to be more descriptive.  I will send an email off for somebody to try it.
Derek
Service pack for Catia v5r17 or excel?
Where can I download Catia v5 service packs anyway? The crooks (I mean reseller) we bought Catia from uses every single setup or support type question we have as a chance milk us like a cash cow. Every stupid little thing you want to know is in one of hundreds of different $1500 - $2000 per person classes they force you to take. You guys on this forum alone have helped save our small company at least $6000+. OK, i'm done venting. Thank you guys very much for your help.
Why don't you just move your account to a new VAR?  You know, you are well within your rights to do that, don't you?
There are options for just this sort of scenario.
If you want service packs, your VAR is under no obligation to provide them, unless he put it in some sort of contract OR if you are on the new VAR model - which is the alternative to the old system of going through IBM for support.
Search the IBM website for "PLM support".  You will need your customer number in order to be able to register for the online access.
Catia Design|Catia Design News|Catia V5 blog
Teabags - office service pack
Hi Teabags... You can sign up on the IBM support site with your IBM customer number. You should have an IBM customer number on your invoice from the VAR. This will allow you to download CATIA service packs & patches. You can also search the CATIA tech Q&A database. Here is the link:
https://www-304.ibm.com/jct03004c/software/applications/plm/support/support.wss
Good luck!
Steve
Letourneau Technologies
OK, time for a shameless plug.
Attend the COE conference next month in Las Vegas.  The cost is relatively low, but the amount of networking; "free" training, and Hints Tips and Techniques that you will learn will more than pay for it.  It's really a weeks worth of experience packed into 3 days.
Visit www.coe.org for more information
Teabags - the office just ran a few Boms out on my Dell64.  No problems with R16 SP5 and R17GA.
Derek
My office is up to date with all of the service packs, I will try to get ahold of any Catia v5 r17 updates and see if i still have the problem.
Found the problem, Windows XP x64 service pack 2.It apparently isn't compatible with Catia v5 r17.
I uninstalled XP x64 SP2 and my spreadsheet problem went away.
Something in the new Windows service pack doesn't allow Catia to interface with excel the way it should.
At least on my windows, office & Catia configuration anyway
Thanks for the update.
By the way - you can still use a Tab delimited plain text document, in place of an Excel spreadsheet.
Yeah I know, it's just a lot easier to edit and add to an Excel spreadsheet in my opinion.
Did you ever find a solution to this problem?
We have the exact same issue with empty spread sheets.
We are running Catia 64bit R17 SP05 and Windows XP 64bit Service Pack 2 with Office 2003.
I use this code to pull the BOM into Excel
Dim oRootDoc
Dim oRootProd
Dim assemblyConvertor1
Set CATIA = GetObject(, "CATIA.Application")
Set oRootDoc = CATIA.ActiveDocument
Set oRootProd = oRootDoc.Product
Set assemblyConvertor1 = oRootProd.GetItem("BillOfMaterial")
Dim arrayOfVariantOfBSTR1(11)
arrayOfVariantOfBSTR1(0) = "Part Number"
arrayOfVariantOfBSTR1(1) = "Quantity"
arrayOfVariantOfBSTR1(2) = "UM"
arrayOfVariantOfBSTR1(3) = "Material"
arrayOfVariantOfBSTR1(4) = "NumeroDeCatalogo"
arrayOfVariantOfBSTR1(5) = "ScrewsName"
arrayOfVariantOfBSTR1(6) = "ScrewsQty"
arrayOfVariantOfBSTR1(7) = "ScrewType"
arrayOfVariantOfBSTR1(8) = "DowelName"
arrayOfVariantOfBSTR1(9) = "DowelQty"
arrayOfVariantOfBSTR1(10) = "DowelType"
Dim assemblyConvertor1Variant As Object
Set assemblyConvertor1Variant = assemblyConvertor1
assemblyConvertor1Variant.SetCurrentFormat arrayOfVariantOfBSTR1
Dim NumOfProducts As Integer
Dim i As Integer
Dim oSubProd 'As product
Dim SourceFileName As String
Dim NumOfSubProducts As Integer
NumOfProducts = oRootProd.Products.count
i = 2
For i = 1 To (NumOfProducts)
    Set oSubProd = oRootProd.Products.Item(i)
    SourceFileName = Folder & "\" & oSubProd.Name & ".xls"
    oSubProd.ExtractBOM catFileTypeHTML, SourceFileName
Yes I got it to work by removing service pack 2 from Windows XP64. Works fine in sp1
