Concrete Basement Wall Design
Case 1: I am trying to design a concrete basement wall and I have columns offset from the wall 10" all the way down to the footing/base of wall. I thought that I could use the column load x the "e=10" to get a point load moment and add it to the lateral load moment to design the wall. Would this be the correct way to go? Or could I just assume that the lateral load moment would couteract column load moment hence making it neglegible? Does anyone have a reference for good examples for basement wall design with a point load?
Case 2: Can I just sum the column loads along the wall divided by the wall length (eg: 1200k/60'=20klf) and use this uniform loading along with the lateral earth pressure an design the wall as a cantilever retaining wall to take the column load rather than using individual footings under each column?
RE: Concrete Basement Wall Design
Please clarify and I know someone will be able to help you (if they beat me to the reply, otherwise I will). It's a really good idea to post a clear sketch of your situation and then post the address for our review prior to helping you out.
Good luck,
I'll check back later,
YS
B.Eng (Carleton)
Working in New Zealand, thinking of my snow covered home...
The columns do not sit on the wall, they go to the base of the wall and sit on the foundation. StructuralEIT your question is a good one so I shouldn't have to worry about the column load in the wall design. On the other hand if I opted to sit the column on pier in the wall then I would need to consider that load for the wall. If this is the way I go then would my previous post be the accurate way?
Now in the case 2 below, whether or not the column is sitting on the wall or at the base of the wall wouldn;t the load have to be included in the retaining wall design, and if so, would this be a correct procedure?
Civilperson are you saying "a combine footing" meaning spread footings for the column load and strip footing underneath the walls?
Thank you all for the input.
I would be careful about turning your column load into a uniform klf load unless they are spaced relatively close together. The foundation will really only behave that way if it is very stiff (thick). Also, if your column loads are significant, you would have to check for punching shear (you should anyway, but is usually not a problem with small loads. On second thought, I definitely would not do it that way, design for the column loads and apply them over a width you feel is reasonable, then design for a 1 ft width based on that loading.
If the column goes to the footing, it should have no part in the design of the wall - only the footing. It will increase your max bearing pressure, but help with the stability analysis. Although, for the stability analysis, you might want to neglect the column loads since most of the wall footing won't see it. But I would definitely include it (worst case) in the footing design.
Thanks again for the advice. I'll be sure to consider this in my analysis.
Thanks for the claification. I will surely look at using the basement wall rather than the retaining wall.
