btu value of 200 degree (F) hydronic stainless pipe
Hello:
I'd like to know to find out how many 3/4" s/steel pipes I would need to heat a 55gal. drum of parifin wax (wt. 335#)to 176 deg.F from room temp. of 68 deg.in 2 hours.
The pipes are filled with water at 200 deg.and ciculated by a pump at 2.3 gpm
The pipes are 3/4" by the length of the barrel (appox. 36"long)
RE: btu value of 200 degree (F) hydronic stainless pipe
Have you looked at any of the hundreds of off the shelf strap-on heaters available?
The only arrangement using hot water to heat drums was in a well insulated room that used hot water radiators with a fan for good circulation.
http://ohmtemp.com/
