soft start specifying
I have seen in here before "rules" of specifying a soft starter concerning voltage rating relationship between motor and starter, and now cannot find it.
I need to specify a soft starter and cannot remember if it needed to be rated higher than the motor or the same voltage...am I thinking of VFD's?
RE: soft start specifying
Now current or 'capacity' wise it some times makes a difference.
Generally if you have starting loads that are rough you might need a "heavier duty" softstarter.
Keith Cress
http://www.eng-tips.com/faqs.cfm?fid=1064
