Composite and S-Video question
I have been searching around unsuccessfully for a solution to my problem.  Please forgive me if it is a basic or trivial problem, I am an ME, not an EE.
I am modding a colecovision for composite and s-video output.  I want to offer both.
right now I have:
chroma               ________________________s-video
____________________/
                    \__________________
                                       \_________composite
luma                 __________________/
                    \________________________s-video
I am getting a lot of interference in both signals.  I am only testing one signal at a time.  I can understand why I'm getting interference in the s-video signal, but why would this give me interference in the composite signal?
More importantly, how do I fix the problem?
Steve
RE: Composite and S-Video question
Are you just tying the chroma and luma signals together directly or are you using caps?
Dan - Owner
http://www.Hi-TecDesigns.com
no cap, just tying the two together
You need a cap in the chroma line... without it you're going to get the color burst signal bleeding into the luma signal.  Figure something in the 1nF range should be good.
Dan - Owner
