ethylene glycol swivel fitting
I'm looking to design a piping system for about 4 coolant lines (3" dia each) carrying ethylene glycol to a shelter resting on an Azimuth turntable. Because the turntable will need less than 3/4 of a rotation, I want to stack 4 swivel fittings over the center of rotation. The expected Pressure requirement is ~200 psi. I was thinking a hydraulic-type fitting might be a source. Any idea where I might find this type of fitting? I prefer to avoid wrapping flexible hose. This is outdoor & must fit thru a 48" dia hole. Does this sound like a commmom application?
RE: ethylene glycol swivel fitting
You can find products similar to theirs on McMaster Carr's website, mcmaster.com. They have some (although only rated for air, not water/glycol) with 4 independent connections in one union.
Two cautions: 1. get epdm seals if at all possible, and plan for leakage. 2. Your application is one of reciprocating motion - try and get a union design that has all fitting threads aligned perpendicular to the axis of rotation, so that the fitting threads won't back off over time.
http://www.kadantjohnson.com/index.html
The size 3" lines would make hoses fairly stiff. There are swivel joints made for tanker and rail car loading arms in that size that would be a good fit for your application.
These vendors also make the fueling hose swivel fittings that you would see at gasoline pumps:
www.opw-fc.com Dover-OPW
www.slytone.co.uk Emco-Wheaton Div Syltone Co
www.fmctechnologies.com FMC Chiksan
Another rotary joint manufacturer in UK,
www.rotaflow.com
