Beam To Girder Analysis
I know you guys can help me on this. I'm having trouble getting something clear in my head on a beam to girder connection analysis. Hypothetical: Let's say there is a floor slab supported by steel floor beams. The floor beams sit atop steel girders, which sit atop the columns (typical situation). For load transfer analysis, I understand this situation. But, what if the beams are welded into the web of the girders, such that they do not sit atop the girders, but instead, the top of the flanges of both members are at a common elevation. Get the scenario? If so, is this connection looked at as pinned or fixed? Also, how does the load from the beam transfer to the girder? I would definitely appreciate the help (young engineer).
lindsbm
lindsbm
RE: Beam To Girder Analysis
In general, these connections were shear connections only. Simple beam connections. In most cases, there is a lack of support to warrant fixity - no upper or lower plates on the flanges to prevent rotation. In most all cases, due to out-of-plane distortion, even if those plates existed it wouldn't do any good as the webs were large enough to rotate out of plane without the additional bracing. This bracing would have to have been top flange and bottom flange and may take the form of a space truss. To avoid that the floor beams were simply designed as simple beams with shear connections at the supports.
The typical steel beam to girder connection is throught clip angles connecting both webs. The shear load is carried by the web of the beam to the welds (or bolts), to the clip angles, to the bolts, and to the web of the girder.
This is the most used type of connection in the industry.
This type of connection is considered "pinned". The clip angles are flexible enough, and they do not "fix" the end of the beam.
AEF
It's a very good question that you ask. It is difficult to visualize this. Let me tell you my way of understanding. I'm going to assume that you will utilize simple shear plate connections, which are the cheapest.
Engineer's loosely assume these connections are pinned. In practice, for buildings anyway, it's considered that for a standard, simple shear plate connection or any other connection only utilizing the web, you don't realy need to know the actual moment. This is because in most offices, the connections are "pre-designed" in the following manner: the simple shear connection is considered to relieve moment by shear yielding in the connection itself, softening the connection, but still supporting the load. Of course some things will need to be prevented, like breaking of the weld, but for the most part, the connection is expected to yield and rotate, relieveing moment, or at least, limiting moment. Visualize the shear yielding in the connection relieving moment.
You should research some AISC-sponsered papers on this at your local college engineering library. Look for back issues of Engineering Journal, published by AISC. This topic is actually very interesting and you will enjoy it. Good luck.
Imagineer
