Another Parallel Leaf Question.
Hope someone can explain to a 'non auto engineer' the basics to this problem.
I was recently informed that occasionaly parallel springs on a rear axle are not always exactly parallel and have some angle in them due to mounting requirements on the rails (toe-in).
I always thought that the shackles could only move fore and aft to accomodate the lengthening and shortening of the spring and were ridgid enough laterally to exclude any other kind of linkage on the axle (e.g. Panhard rod).
How is it possible then, for the shackle to tolerate this misalignment and still give lateral support? Won't the shackles bind, or at best wear very quickly on the inside if they are forced to move exactly fore and aft along the cars centreline when they could possibly be at a 3 or 4 degree angle to each other (I estimated the angle based on angle of chassis rails)?
What am I missing? Thanks for your time.
RE: Another Parallel Leaf Question.
Shackles not infinitely rigid in the lateral direction?
Shackle pins intentionally not parallel to the vehicle Y-axis?
Norm
And I think that a Panhard rod is an excellent idea for a Hotchkiss.
Cheers
Greg Locock
OK I can see that the bushings would be capable of this if soft enough but it can't do anything for precise handling. I assume that's what Greg meant about the Panhard rod.
I know the shackle linkage is not that solid but forcing it to twist when it is not designed too just doesn't seem 'proper'.
Angling the shackle pins seem like a much better idea.
Do you think shackles fore and aft would improve things or be unnecesary? (Assuming suitable linkage for axle alignment of course).
Thanks again for your time.
By the time you've added a longitudinal link to each axle end and a PHB for lateral control, you're 3/4 of the way toward a 3-link.
Not that some rather complex arrangements involving longitudinally-oriented leaf springs have never been tried, or have never had any success in competition - I happen to have handy a brief description of a real oddball. Leaf springs with a swivel arrangement in each pad, upper and lower links each side, and a Watts link for lateral location.
Norm
Cheers
Greg Locock
