Current Transformer Limits
Can a 150:5 CT survive a 25-30kA fault current?
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Current Transformer Limits
Window-type or wound primary?
If medium voltage wound type, this answer is most probably no. Normal thermal rating is 100 x Inom, which would be 15 kA.
I assume most of the above comments are assuming a window-type CT or bushing CT. Remember even those have limits on how much current the secondary windings can take without damage...even if a short-time current. Considering your case above, for a 25 kA primary current, the secondary peak current could reach 833A (25 kA / 150/5). While the core would saturate well below that level more than likely, the saturation point is a function of the connected burden. If the burden was electronic and the leads relatively short, then the secondary current could get pretty high and could indeed cause damage.
mm
Yes...the manufacturer should be able to tell you.
Also, there should be a thermal and dynamic current rating marked on the nameplate.
I think you're talking about the accuracy of a CT, i.e. C800 or 5P20 rating and it is related to burden.
The ability of a CT to physically handle (handle meaning without damage) is not related to the applied burden and is really only a function of the cross-sectional area of the windings used in the primary and secondary and the mechanical design of such.
