Air Cooler Design: multiple services in the same bay
I am designing an Air cooled Heat Exchanger (API 661), forced draft. And I have three bundles (each bundle handle a different service and the three are on one bundle sharing the pair of fans.
Could the bundles be completely different from each other, (it means, different number of rows, tube pitch, etc).
For the design, it should be considered an equal static pressure drop for the total bay. And this could be accomplished if bundles are different (different air flow will circulate through each bundle) But I suspect this is an unreal behavior, because fans not always are at the same conditions, process conditions may vary, etc…
Your comments will be highly appreciated
GH
RE: Air Cooler Design: multiple services in the same bay
In my opinion, the foremost criterion for this is that the static pressures across all three tube bundles should match, because that's what will happen anyway. However, I think there are different opinions about the bundle configurations between cooler manufacturers. I also think that the more similar the bundles are in terms of tube pitch, tube diameter, and number of tube rows, the better.
I suppose it comes down to a question of how confident you are in the correlations you are using for the design.
speco (www.stoneprocess.com)
Elie Abou Jaoudeh
