Basic Dual Dimensions
Hi All,
I am new to this forum but had a question if any of you know what a Basic dual dimension should look like or if there is a standard that depicts this.
Marc
also, is there a way to upload files?  That would help you to understand more what i am asking.
RE: Basic Dual Dimensions
Look at the ASME Y14 standards on drafting.
thank you but I have ASME 14.5 and caoont find anything in it referring to this.
ASME Y14.5M-1994
Section 1.3.9 Basic Dimension - A numerical values used to describe the theorectically exact size, profile, orientation or location of a feature or datum target.
Section 1.3.10 Reference Dimension - A dimension, usually without tolerance, used for information purpose only.  A reference dimension is a repeat of a dimension or is derived from other values shown on the drawing or  on related drawings.  It is considered auxiliary information and does not govern production or inspection operations.
I think your key answer is in the word derived.  The dual dimension is derived from the primary dimension that happens to be basic.
Heckler
Sr. Mechanical Engineer
SWx 2007 SP 3.0 & Pro/E 2001
XP Pro SP2.0 P4 3.6 GHz, 1GB RAM
NVIDIA Quadro FX 1400
      o
  _`\(,_
(_)/ (_)
(In reference to David Beckham) "He can't kick with his left foot, he can't tackle, he can't head the ball and he doesn't score many goals. Apart from that, he's all right."  -- George Best
DrawingsGuy,
   A basic dual dimension sounds to me like a mistake.  I provide alternate units for reference only.  Only the official dimension can be basic.
   Check out the Drafting Standards, GD&T & Tolerance Analysis forum.
                        JHG
