Crude Overhead Reflux (cold) Exchangers
Has anyone here ever installed crude overhead reflux exchangers with the crude on the shell side and vapor on the tube side? (These are the exchangers downstream of the reflux drum and before the fin fan cooling). If so, what were the benefits and problems of configuring the services this way??
We have had severe corrosion problems with existing twisted tube HEXs with vapor on the shell side. We have a proposed design to swap the services.
RE: Crude Overhead Reflux (cold) Exchangers
Proper crude oil desalting process is 90% of battling corrosion problems in the overhead system. Make sure that your desalter runs with minimum 80% efficiency (if single stage) or 97-99% efficiency (two-stage). Ensure the absolute control of chemical dozing (neutralizer, corrosion inhibitor) and check overhead pH more frequently, 2-4 times per shift at least. Your problem in the heat exchangers is "first droplet condensation issue", and is originating from high HCL content of the column overhead vapors. Changing heat exchanger fluid allocation and/or design will simply not solve the problem.
Don't believe swapping services will correct the corrosion, but we are hoping to improve our corrosion rates and not buy bundles annually and plug tubes semi-annually. U-tubes are much less expensive to replace than the twisted tube design, as well. Trying to gather info about whether to expect better or worse corrosion issues by swapping services and what the drawbacks could be. New swapped service design addresses pressure drop (maintains the same as twisted tube). The alternative with straight tube was far too large at 72"D!
Have you considered changing metallurgy ?
We talked to PCS this morning, and they said they know of 4 crude units with the services swapped. 3 of the 4 have water wash systems, and the 4th is in S. America. Your "first droplet condensation" comment was also mentioned as an issue with the horizontal design and eventual tube corrosion (companies with this design metallurgy up). Sounds like a no-go for us until we install a wash system.
Using inappropriate neutralizing chemical makes the situation worse, because of amine salt accumulation problem in the reflux loop. Have you analized O/H receiver condensate for NH3, Fe and Cl? What is the most frequent pH value? What is the average salt content in desalted crude and what test methos do you use? Any caustic addition downstream of desalter?
Also, be aware of LMTD reduction after installing waterwash system, which means you must make a compensation with additional heat exchange area.
Please check other parameters I asked about in my previous post.
It quite useful for your case
Hanon
What are the temps on this unit? Have you thought about a superferritic tube material?
Rust never sleeps
Neither should your protection
http://www.trent-tube.com/contact/Tech_Assist.cfm
