Material database
Material database
Material database
I am updating my material database.
If anyone would like to add materials, please let me know and I will try to add.
It would help me save time if you have the material specs, and an image of the material, if you have it.
You can download the file from my site below.
Chris
SolidWorks 07 3.0/PDMWorks 07
AutoCAD 06
ctopher's home (updated 03-13-07)
RE: Material database
How about some cast aluminum materials:
C355=.101 density
A356=.097 density
Wrought aluminum material:
2014=.101
Low Alloy Steel materials:
4130=.283 density
4140=.283 density
4340=.283 density
and other miscellaneous materials:
Leaded Bronze=.326 density
Carbon=.056 density
All above materials are commonly used in aerospace designs
Macduff spin
Colin Fitzpatrick
Mechanical Design Engineer
Solidworks 2007 SP 2.2
Dell 390 XP Pro SP 2
nVida Quadro FX 3450/4000
Oh...and a star for you for supporting us SW users, and for having a cool website.
Best,
Macduff spin
Colin Fitzpatrick
Thanks Colin.
I will look into those mtls.
cheers
Chris
AutoCAD 06
Colin,
Can you be more specific on the Carbon?
Chris
AutoCAD 06
ctopher's home (updated 03-26-07)
Chris,
I'll have to get back to you on that. It's been awhile since I worked with carbon. I think just a generic grade. What did you find?
Macduff spin
Colin Fitzpatrick
pdybeck,
What do have available in carbon?
You know you guys.........we're going to have to take Chris out for a steak dinner for working on this. Oh......and for some beers too!
Macduff spin
Colin Fitzpatrick
Colin,
Carbon steels (and some stainless to boot)
STEEL ROUND BAR, ELASTUF PENN CF
STEEL ROUND BAR, ELASTUF A-2 HR
STEEL ROUND BAR, ELASTUF PENN HR
STEEL ROUND BAR, ELASTUF PB HR
STEEL ROUND BAR, A36 HFS
STEEL ROUND BAR, A36 MILD HR
STEEL ROUND BAR, 1010 HR
STEEL ROUND BAR, 1010 CD
STEEL ROUND BAR, 1017 CD
STEEL ROUND BAR, 1017 HR
STEEL ROUND BAR, 1018 CD STRESS RELIEVED
STEEL ROUND BAR, 1018 CFS
STEEL ROUND BAR, 1018 HR AS-ROLLED
STEEL ROUND BAR, 1018 HR NORMALIZED
STEEL ROUND BAR, 1018 HR ANNEALED
STEEL ROUND BAR, 1020 HR
STEEL ROUND BAR, 1040/42/45 HR AS-ROLLED
STEEL ROUND BAR, 1040/42/45 HR NORMALIZED
STEEL ROUND BAR, 1040/42/45 HR ANNEALED
STEEL ROUND BAR, 1040/42/45 CFS
STEEL ROUND BAR, 1117 HR AS-ROLLED
STEEL ROUND BAR, 1117 HR NORMALIZED
STEEL ROUND BAR, 1117 HR ANNEALED
STEEL ROUND BAR, 1117/11L17 CFS
STEEL ROUND BAR, 1117 CD STRESS RELIEVED
STEEL ROUND BAR, 1137 CFS
STEEL ROUND BAR, 1141 CFS
STEEL ROUND BAR, 1141 HR AS-ROLLED
STEEL ROUND BAR, 1141 HR NORMALIZED
STEEL ROUND BAR, 1141 HR ANNEALED
STEEL ROUND BAR, 1144 CD STRESS RELIEVED
STEEL ROUND BAR, 1144 LASALLE STRESSPROOF CFS
STEEL ROUND BAR, 1144 LASALLE FATIGUEPROOF CFS
STEEL ROUND BAR, 12L14 LEDLOY CFS
STEEL ROUND BAR, 1215 CD
STEEL ROUND BAR, LASALLE ETD 150 CF
STEEL ROUND BAR, 4140 HFS AS-ROLLED
STEEL ROUND BAR, 4140 HFS ANNEALED
STEEL ROUND BAR, 4100, 4300, 9800 Q & T PER ASTM A434-90a CLASS BD
STEEL ROUND BAR, 8620 HFS AS-ROLLED
STEEL ROUND BAR, 8620 HFS ANNEALED
STEEL ROUND BAR, 8620 CDS ANNEALED
STEEL STAINLESS ROUND BAR, 303 HR ANNEALED
STEEL STAINLESS ROUND BAR, 303 CF
STEEL STAINLESS ROUND BAR, 303S HR ANNEALED
STEEL STAINLESS ROUND BAR, 303S CF
STEEL STAINLESS ROUND BAR, 303Se HR ANNEALED
STEEL STAINLESS ROUND BAR, 303Se CF
STEEL STAINLESS ROUND BAR, 304 HF TYPE A
STEEL STAINLESS ROUND BAR, 304 CF TYPE A
STEEL STAINLESS ROUND BAR, 304 TYPE A, CF
STEEL STAINLESS ROUND BAR, 316 HF TYPE A
STEEL STAINLESS ROUND BAR, 316 CF TYPE A
STEEL STAINLESS ROUND BAR, AISI TYPE 329 ANNEALED
STEEL STAINLESS ROUND BAR, 416 TYPE A
STEEL STAINLESS ROUND BAR, 416 HEAT TREAT COND. T
STEEL STAINLESS ROUND BAR, 17-4 PH COND. H 1150 TYPE 630
STEEL STAINLESS ROUND BAR, 17-4 PH COND. A TYPE 630
STEEL STAINLESS ROUND BAR, 17-4 PH COND. H 900 TYPE 630
Material Properties are per ASTM specs when avalaible...
Pete
pdybeck,
I meant plain carbon graghite material. Used for bearings in the aerospace arena.
Chris,
Poco was the manufacture I dealt with in the past for carbon. my density might be off by little. Maybe make a generic material for this in the SW database.
Macduff spin
Colin Fitzpatrick
carbon schmarbon...
Pete
Thanks guys.
I could make diamond for carbon, but it's hard to do.bigsmile
Chris
AutoCAD 06
Chris,
How about adding some density for Printed Wiring Boards like:
Premix Thermoplastics PRE-ELEC® ESD 4100=0.0343 lb/in³
I would like to hear from of the electrical folks out there. They might be more specific than us mechanical guys.
Macduff spin
Colin Fitzpatrick
I'll look into it. There are more than one mtl for PCB's. I will need to look more than just density.
Thanks.
Chris
AutoCAD 06
Many materials for PCB's I imagine would be anisotropic (material response is dependent upon direction/orientation of a force relative to the material - think laminates/ply materials).  You could not simply input a global modulus.  You would need to define a modulus of elasticity for multiple directions/orientations.  I think this is where some more serious FEA programs come into play.  I think most of them come with some more serious libraries of materials and the ability to capture maerial properties for materials such as these. I mention this because the material database in SolidWorks is intended to work with Cosmos.  I wonder if the material database can be carried over to a program like Cosmos Professional.  Does the material database play nicely across those programs?  Anyone in the know?
Pete
I have used these mtls in COSMOS and they worked well. Major aerospace companies and the US military bought into the FEA we did.
Chris
AutoCAD 06
Chris, can the material database in basic SolidWorks "scale" up to cover these types of materials, or is it when you get into evaluating these types of materials/scenarios you just bag the solidworks material database and use a more extensive library.  If the latter is the case, it would make more sense for us to submit an enhancement request for SolidWorks to set up the materials database to scale up to these situations so that we can put our time into adding material info to an animal that has the chance of being around for a while...
Pete
Pete,
I don't understand what you mean by "scale" up.
Chris
AutoCAD 06
Lets say you spend all this time adding material info to the SolidWorks material database and it works great with solidWorks and Cosmos Designer.  But lets say down the road you start using an FEA package that can analyze the materials that are anisotropic (laminates/plys/non-linear behaving materials).  Can you still use the SolidWorks materials database that you spent all that time adding info to, or are you stuck re-creating all that information into another library/database that works with your more advanced FEA package.  That is what I mean by scaling up...
Pete
With the database I created, I have been able to use it in COSMOSWorks & FloWorks without problems. I think it was up to SolidWorks 2005 we had to have a separate databse. Now, it's just one for all.
For a check, if anyone has CW or FW, please use the mtls and let me know how it works for you.
Thanks.
Chris
AutoCAD 06
Chris,
    Can CosmosWorks analyze materials that are anisotropic in nature?  If so, does it just add fields to the SolidWorks material database?  I haven't seen anything in the SolidWorks material database that shows this ability...
Does Advanced Professional use the SolidWorks material database, or can it?  Does it have its own database?  I looked at the SolidWorks material database a little closer and noticed the annotation is in the form EX for modulus of Elasticity, SIGXT for tensile stength, KX for thermal conductivity.  The "X" to me seems like it could distinguish values in the X direction/sense.  I am wondering if Cosmos Advanced Professional adds fields like EY and EZ, and SIGYT and SIGYZ, and KY and KZ to the existing SolidWorks material database...
Pete
