Cable impedance
Cable impedance
Cable impedance
Hi guys!
I'm trying to build a cable impedance database that could be used in my studies.
Does somebody know a good reference about cable impedance including various types of cables, various voltage level, etc.
Thanks!
JPEG
RE: Cable impedance
What studies? They should be included in your software. You can also use the c values to calculate your f factor if you are doing a point to point s/c study.
RE: Cable impedance
Several references off hand:
1.  Westinghouse Transmission and Distribution Book
2.  Aluminum Electrical Conductor Handbook
3.  Cooper Power Systems' Distribution System Protection
    Manual.  This has a good positive and zero sequence
    listing of impedances.
Pirelli also has a readily available listing of pos. and zero sequence impedances.
RE: Cable impedance
Unfortunatly, my software database is very limited when it's not teck cables...
RE: Cable impedance
I seen a meter at the IEEE safety workshop that will do exactly what you are wanting... It will give cable lenghts, impedances, X/R ratios, ect. www.zmeters.com
