Mechanical Room Shunt trip
I have a room that holds about 10 pumps of all sizes, 3 chillers (2 centrifugal (R-123) , 1 Screw (R -134a), A HX, 6 VFD drives and A MCC in the central plant. When you design for a shut down or panic button is the intent on shutting down the Chillers themselves or is the intent on shutting down the Central plant as a whole? Keep in mind i have a Refigerant monitor Whith bells and whistles and a 24 hour operting ex fan for the emergency ventilation. I would think you would want the plant to shut down not just the chillers themselves. Any help would be appreciated
thank you
thank you
RE: Mechanical Room Shunt trip
With electrical equipment the danger would be electrocution so a panic button should cut off all electrical supplies.
Note that suddenly cutting power to chillers does have potential for damaging the equipment!
