I tried Linear and Circular patterns and would not work.
Can someone please give some hints on how to make 1 inch holes every 20 inches on a part that has a combination of linear and semi-circular edges. I tried Linear and Circular patterns and would not work.
The part measures 20 feet long and it looks like a giant rubber band stretched out.
Using SW2007
Using SW2007
RE: I tried Linear and Circular patterns and would not work.
would probably help us to
help you more ably.
SW07-SP3
http://www.telemetrika.com//_Postings.html
I think a sketch driven pattern will work much better. (Make a sketch with all the points (point represent the centerpoints of the arc locations for your holes) Then exit the sketch select sketch driven pattern and pick the sketch and then the Already made feature)
Scott Baugh, CSWP![[pc2] pc2](https://www.tipmaster.com/images/pc2.gif)
www.scottjbaugh.com
FAQ731-376
Can someone please help.
http://www.yourfilelink.com/get.php?fid=305616
SW07-SP3
Also if you had just followed the steps I listed above you would have understood the process.
www.scottjbaugh.com
FAQ731-376
In what tutorial does the Curve driven pattern is explained or appears?
www.scottjbaugh.com
FAQ731-376
SW07-SP3
