Ext. and interior steel pipe coatings for potable water
Do you have some advantages/disatvantages for steel pipe coatings? Any suggestion which to use (economical and tecnical reasons)?
For example:
AWWA C203 Coal-Tar Protective Coatings and Linings for Steel Water Pipelines
AWWA C210 Liquid-Epoxy Coating Systems for the Interior and Exterior of Steel Water Pipelines
For example:
RE: Ext. and interior steel pipe coatings for potable water
It will also make a difference whether you're looking a few odd pieces or miles of pipe.
