Propane Screw Compressor control
I am working on a scheme to install screw compressor in a closed loop propane referigeration circuit. Can someone enlighten me the different kinds of controls for this applications. I have seen valve unloader using suction pressure to control. How does the discharge pressure controlled?
Thanks in advance
Thanks in advance
RE: Propane Screw Compressor control
David
In refrigeration systems it is usually the condenser, located nearby, that fixes the discharge pressure which corresponds to the vapor pressure of the refrigerant (propane), line friction drops are usually small in comparison.
Can you tell us the reason for selecting a screw compressor for propane ?
You misunderstood my post if you thought that "flow resistance within the system" meant line friction. I meant all flow resistance, including the condenser, TXV, throttled valves, friction, or whatever else takes a pressure drop. Without knowing the system it really is impossible to say which component will control within a given system.
BTW Propane is a very common refrigerent in Oil & Gas facilities, it seems to work just fine.
David
David Simpson, PE
MuleShoe Engineering
www.muleshoe-eng.com
The harder I work, the luckier I seem
A screw compressor will have a fixed ratio, doesn't matter what the system resistance is it'll do that ratio. You can change the raio automatically with newer units. The control is complex, because you have 3 controllers and each one will change the performance and most of all the efficency.
Visit thread404-181559 and the links therein.
