Huge Difference Between Free Meshing (AdvancingFront) and Structu
I was testing the performance difference between Free Meshing and Structural Meshing techniques.
 For the same very simple model (square) I use first  Structural meshing
Then I used Free meshing technique (ADVANCING FRONT for the same model .Both meshes have  the same type and very much almost the same Number of elements . The two meshes look topogically even identical.
Suprisingly each one give extremely different response from the other. The AdvancingFront Free one leads to much higher strain and displacement field than the structural one. That results shocked me. If you do not beleive Below are the inp files of each of two meshes . Please try and give a comment about that (Note the two input files are seperated by contiuous line)
*Heading
** Job name: Structural Model name: Model-1
*Preprint, echo=NO, model=NO, history=NO, contact=NO
** PARTS
*Part, name=Part-1
*Node
      1,           0.,           0.
      2,   11.1111107,           0.
      3,   22.2222214,           0.
      4,   33.3333321,           0.
      5,   44.4444427,           0.
      6,   55.5555573,           0.
      7,   66.6666641,           0.
      8,   77.7777786,           0.
      9,   88.8888855,           0.
     10,         100.,           0.
     11,   111.111115,           0.
     12,   122.222221,           0.
     13,   133.333328,           0.
     14,   144.444443,           0.
     15,   155.555557,           0.
     16,   166.666672,           0.
     17,   177.777771,           0.
     18,   188.888885,           0.
     19,         200.,           0.
     20,   211.111115,           0.
     21,   222.222229,           0.
     22,   233.333328,           0.
     23,   244.444443,           0.
     24,   255.555557,           0.
     25,   266.666656,           0.
     26,   277.777771,           0.
     27,   288.888885,           0.
     28,         300.,           0.
     29,   311.111115,           0.
     30,   322.222229,           0.
     31,   333.333344,           0.
     32,   344.444458,           0.
     33,   355.555542,           0.
     34,   366.666656,           0.
     35,   377.777771,           0.
     36,   388.888885,           0.
     37,         400.,           0.
     38,   411.111115,           0.
     39,   422.222229,           0.
     40,   433.333344,           0.
     41,   444.444458,           0.
     42,   455.555542,           0.
     43,   466.666656,           0.
     44,   477.777771,           0.
     45,   488.888885,           0.
     46,         500.,           0.
     47,   511.111115,           0.
     48,   522.222229,           0.
     49,   533.333313,           0.
     50,   544.444458,           0.
     51,   555.555542,           0.
     52,   566.666687,           0.
     53,   577.777771,           0.
     54,   588.888916,           0.
     55,         600.,           0.
     56,           0.,   11.1111107
     57,   11.1111107,   11.1111107
     58,   22.2222214,   11.1111107
     59,   33.3333321,   11.1111107
     60,   44.4444427,   11.1111107
     61,   55.5555573,   11.1111107
     62,   66.6666641,   11.1111107
     63,   77.7777786,   11.1111107
     64,   88.8888855,   11.1111107
     65,         100.,   11.1111107
     66,   111.111115,   11.1111107
     67,   122.222221,   11.1111107
     68,   133.333328,   11.1111107
     69,   144.444443,   11.1111107
     70,   155.555557,   11.1111107
     71,   166.666672,   11.1111107
     72,   177.777771,   11.1111107
     73,   188.888885,   11.1111107
     74,         200.,   11.1111107
     75,   211.111115,   11.1111107
     76,   222.222229,   11.1111107
     77,   233.333328,   11.1111107
     78,   244.444443,   11.1111107
     79,   255.555557,   11.1111107
     80,   266.666656,   11.1111107
     81,   277.777771,   11.1111107
     82,   288.888885,   11.1111107
     83,         300.,   11.1111107
     84,   311.111115,   11.1111107
     85,   322.222229,   11.1111107
     86,   333.333344,   11.1111107
     87,   344.444458,   11.1111107
     88,   355.555542,   11.1111107
     89,   366.666656,   11.1111107
     90,   377.777771,   11.1111107
     91,   388.888885,   11.1111107
     92,         400.,   11.1111107
     93,   411.111115,   11.1111107
     94,   422.222229,   11.1111107
     95,   433.333344,   11.1111107
     96,   444.444458,   11.1111107
     97,   455.555542,   11.1111107
     98,   466.666656,   11.1111107
     99,   477.777771,   11.1111107
    100,   488.888885,   11.1111107
    101,         500.,   11.1111107
    102,   511.111115,   11.1111107
    103,   522.222229,   11.1111107
    104,   533.333313,   11.1111107
    105,   544.444458,   11.1111107
    106,   555.555542,   11.1111107
    107,   566.666687,   11.1111107
    108,   577.777771,   11.1111107
    109,   588.888916,   11.1111107
    110,         600.,   11.1111107
    111,           0.,   22.2222214
    112,   11.1111107,   22.2222214
    113,   22.2222214,   22.2222214
    114,   33.3333321,   22.2222214
    115,   44.4444427,   22.2222214
    116,   55.5555573,   22.2222214
    117,   66.6666641,   22.2222214
    118,   77.7777786,   22.2222214
    119,   88.8888855,   22.2222214
    120,         100.,   22.2222214
    121,   111.111115,   22.2222214
    122,   122.222221,   22.2222214
    123,   133.333328,   22.2222214
    124,   144.444443,   22.2222214
    125,   155.555557,   22.2222214
    126,   166.666672,   22.2222214
    127,   177.777771,   22.2222214
    128,   188.888885,   22.2222214
    129,         200.,   22.2222214
    130,   211.111115,   22.2222214
    131,   222.222229,   22.2222214
    132,   233.333328,   22.2222214
    133,   244.444443,   22.2222214
    134,   255.555557,   22.2222214
    135,   266.666656,   22.2222214
    136,   277.777771,   22.2222214
    137,   288.888885,   22.2222214
    138,         300.,   22.2222214
    139,   311.111115,   22.2222214
    140,   322.222229,   22.2222214
    141,   333.333344,   22.2222214
    142,   344.444458,   22.2222214
    143,   355.555542,   22.2222214
    144,   366.666656,   22.2222214
    145,   377.777771,   22.2222214
    146,   388.888885,   22.2222214
    147,         400.,   22.2222214
    148,   411.111115,   22.2222214
    149,   422.222229,   22.2222214
    150,   433.333344,   22.2222214
    151,   444.444458,   22.2222214
    152,   455.555542,   22.2222214
    153,   466.666656,   22.2222214
    154,   477.777771,   22.2222214
    155,   488.888885,   22.2222214
    156,         500.,   22.2222214
    157,   511.111115,   22.2222214
    158,   522.222229,   22.2222214
    159,   533.333313,   22.2222214
    160,   544.444458,   22.2222214
    161,   555.555542,   22.2222214
    162,   566.666687,   22.2222214
    163,   577.777771,   22.2222214
    164,   588.888916,   22.2222214
    165,         600.,   22.2222214
    166,           0.,   33.3333321
    167,   11.1111107,   33.3333321
    168,   22.2222214,   33.3333321
    169,   33.3333321,   33.3333321
    170,   44.4444427,   33.3333321
    171,   55.5555573,   33.3333321
    172,   66.6666641,   33.3333321
    173,   77.7777786,   33.3333321
    174,   88.8888855,   33.3333321
    175,         100.,   33.3333321
    176,   111.111115,   33.3333321
    177,   122.222221,   33.3333321
    178,   133.333328,   33.3333321
    179,   144.444443,   33.3333321
    180,   155.555557,   33.3333321
    181,   166.666672,   33.3333321
    182,   177.777771,   33.3333321
    183,   188.888885,   33.3333321
    184,         200.,   33.3333321
    185,   211.111115,   33.3333321
    186,   222.222229,   33.3333321
    187,   233.333328,   33.3333321
    188,   244.444443,   33.3333321
    189,   255.555557,   33.3333321
    190,   266.666656,   33.3333321
    191,   277.777771,   33.3333321
    192,   288.888885,   33.3333321
    193,         300.,   33.3333321
    194,   311.111115,   33.3333321
    195,   322.222229,   33.3333321
    196,   333.333344,   33.3333321
    197,   344.444458,   33.3333321
    198,   355.555542,   33.3333321
    199,   366.666656,   33.3333321
    200,   377.777771,   33.3333321
    201,   388.888885,   33.3333321
    202,         400.,   33.3333321
    203,   411.111115,   33.3333321
    204,   422.222229,   33.3333321
    205,   433.333344,   33.3333321
    206,   444.444458,   33.3333321
    207,   455.555542,   33.3333321
    208,   466.666656,   33.3333321
    209,   477.777771,   33.3333321
    210,   488.888885,   33.3333321
    211,         500.,   33.3333321
    212,   511.111115,   33.3333321
    213,   522.222229,   33.3333321
    214,   533.333313,   33.3333321
    215,   544.444458,   33.3333321
    216,   555.555542,   33.3333321
    217,   566.666687,   33.3333321
    218,   577.777771,   33.3333321
    219,   588.888916,   33.3333321
    220,         600.,   33.3333321
    221,           0.,   44.4444427
    222,   11.1111107,   44.4444427
    223,   22.2222214,   44.4444427
    224,   33.3333321,   44.4444427
    225,   44.4444427,   44.4444427
    226,   55.5555573,   44.4444427
    227,   66.6666641,   44.4444427
    228,   77.7777786,   44.4444427
    229,   88.8888855,   44.4444427
    230,         100.,   44.4444427
    231,   111.111115,   44.4444427
    232,   122.222221,   44.4444427
    233,   133.333328,   44.4444427
    234,   144.444443,   44.4444427
    235,   155.555557,   44.4444427
    236,   166.666672,   44.4444427
    237,   177.777771,   44.4444427
    238,   188.888885,   44.4444427
    239,         200.,   44.4444427
    240,   211.111115,   44.4444427
    241,   222.222229,   44.4444427
    242,   233.333328,   44.4444427
    243,   244.444443,   44.4444427
    244,   255.555557,   44.4444427
    245,   266.666656,   44.4444427
    246,   277.777771,   44.4444427
    247,   288.888885,   44.4444427
    248,         300.,   44.4444427
    249,   311.111115,   44.4444427
    250,   322.222229,   44.4444427
    251,   333.333344,   44.4444427
    252,   344.444458,   44.4444427
    253,   355.555542,   44.4444427
    254,   366.666656,   44.4444427
    255,   377.777771,   44.4444427
    256,   388.888885,   44.4444427
    257,         400.,   44.4444427
    258,   411.111115,   44.4444427
    259,   422.222229,   44.4444427
    260,   433.333344,   44.4444427
    261,   444.444458,   44.4444427
    262,   455.555542,   44.4444427
    263,   466.666656,   44.4444427
    264,   477.777771,   44.4444427
    265,   488.888885,   44.4444427
    266,         500.,   44.4444427
    267,   511.111115,   44.4444427
    268,   522.222229,   44.4444427
    269,   533.333313,   44.4444427
    270,   544.444458,   44.4444427
    271,   555.555542,   44.4444427
    272,   566.666687,   44.4444427
    273,   577.777771,   44.4444427
    274,   588.888916,   44.4444427
    275,         600.,   44.4444427
    276,           0.,   55.5555573
    277,   11.1111107,   55.5555573
    278,   22.2222214,   55.5555573
    279,   33.3333321,   55.5555573
    280,   44.4444427,   55.5555573
    281,   55.5555573,   55.5555573
    282,   66.6666641,   55.5555573
    283,   77.7777786,   55.5555573
    284,   88.8888855,   55.5555573
    285,         100.,   55.5555573
    286,   111.111115,   55.5555573
    287,   122.222221,   55.5555573
    288,   133.333328,   55.5555573
    289,   144.444443,   55.5555573
    290,   155.555557,   55.5555573
    291,   166.666672,   55.5555573
    292,   177.777771,   55.5555573
    293,   188.888885,   55.5555573
    294,         200.,   55.5555573
    295,   211.111115,   55.5555573
    296,   222.222229,   55.5555573
    297,   233.333328,   55.5555573
    298,   244.444443,   55.5555573
    299,   255.555557,   55.5555573
    300,   266.666656,   55.5555573
    301,   277.777771,   55.5555573
    302,   288.888885,   55.5555573
    303,         300.,   55.5555573
    304,   311.111115,   55.5555573
    305,   322.222229,   55.5555573
    306,   333.333344,   55.5555573
    307,   344.444458,   55.5555573
    308,   355.555542,   55.5555573
    309,   366.666656,   55.5555573
    310,   377.777771,   55.5555573
    311,   388.888885,   55.5555573
    312,         400.,   55.5555573
    313,   411.111115,   55.5555573
    314,   422.222229,   55.5555573
    315,   433.333344,   55.5555573
    316,   444.444458,   55.5555573
    317,   455.555542,   55.5555573
    318,   466.666656,   55.5555573
    319,   477.777771,   55.5555573
    320,   488.888885,   55.5555573
    321,         500.,   55.5555573
    322,   511.111115,   55.5555573
    323,   522.222229,   55.5555573
    324,   533.333313,   55.5555573
    325,   544.444458,   55.5555573
    326,   555.555542,   55.5555573
    327,   566.666687,   55.5555573
    328,   577.777771,   55.5555573
    329,   588.888916,   55.5555573
    330,         600.,   55.5555573
    331,           0.,   66.6666641
    332,   11.1111107,   66.6666641
    333,   22.2222214,   66.6666641
    334,   33.3333321,   66.6666641
    335,   44.4444427,   66.6666641
    336,   55.5555573,   66.6666641
    337,   66.6666641,   66.6666641
    338,   77.7777786,   66.6666641
    339,   88.8888855,   66.6666641
    340,         100.,   66.6666641
    341,   111.111115,   66.6666641
    342,   122.222221,   66.6666641
    343,   133.333328,   66.6666641
    344,   144.444443,   66.6666641
    345,   155.555557,   66.6666641
    346,   166.666672,   66.6666641
    347,   177.777771,   66.6666641
    348,   188.888885,   66.6666641
    349,         200.,   66.6666641
    350,   211.111115,   66.6666641
    351,   222.222229,   66.6666641
    352,   233.333328,   66.6666641
    353,   244.444443,   66.6666641
    354,   255.555557,   66.6666641
    355,   266.666656,   66.6666641
    356,   277.777771,   66.6666641
    357,   288.888885,   66.6666641
    358,         300.,   66.6666641
    359,   311.111115,   66.6666641
    360,   322.222229,   66.6666641
    361,   333.333344,   66.6666641
    362,   344.444458,   66.6666641
    363,   355.555542,   66.6666641
    364,   366.666656,   66.6666641
    365,   377.777771,   66.6666641
    366,   388.888885,   66.6666641
    367,         400.,   66.6666641
    368,   411.111115,   66.6666641
    369,   422.222229,   66.6666641
    370,   433.333344,   66.6666641
    371,   444.444458,   66.6666641
    372,   455.555542,   66.6666641
    373,   466.666656,   66.6666641
    374,   477.777771,   66.6666641
    375,   488.888885,   66.6666641
    376,         500.,   66.6666641
    377,   511.111115,   66.6666641
    378,   522.222229,   66.6666641
    379,   533.333313,   66.6666641
    380,   544.444458,   66.6666641
    381,   555.555542,   66.6666641
    382,   566.666687,   66.6666641
    383,   577.777771,   66.6666641
    384,   588.888916,   66.6666641
    385,         600.,   66.6666641
    386,           0.,   77.7777786
    387,   11.1111107,   77.7777786
    388,   22.2222214,   77.7777786
    389,   33.3333321,   77.7777786
    390,   44.4444427,   77.7777786
    391,   55.5555573,   77.7777786
    392,   66.6666641,   77.7777786
    393,   77.7777786,   77.7777786
    394,   88.8888855,   77.7777786
    395,         100.,   77.7777786
    396,   111.111115,   77.7777786
    397,   122.222221,   77.7777786
    398,   133.333328,   77.7777786
    399,   144.444443,   77.7777786
    400,   155.555557,   77.7777786
    401,   166.666672,   77.7777786
    402,   177.777771,   77.7777786
    403,   188.888885,   77.7777786
    404,         200.,   77.7777786
    405,   211.111115,   77.7777786
    406,   222.222229,   77.7777786
    407,   233.333328,   77.7777786
    408,   244.444443,   77.7777786
    409,   255.555557,   77.7777786
    410,   266.666656,   77.7777786
    411,   277.777771,   77.7777786
    412,   288.888885,   77.7777786
    413,         300.,   77.7777786
    414,   311.111115,   77.7777786
    415,   322.222229,   77.7777786
    416,   333.333344,   77.7777786
    417,   344.444458,   77.7777786
    418,   355.555542,   77.7777786
    419,   366.666656,   77.7777786
    420,   377.777771,   77.7777786
    421,   388.888885,   77.7777786
    422,         400.,   77.7777786
    423,   411.111115,   77.7777786
    424,   422.222229,   77.7777786
    425,   433.333344,   77.7777786
    426,   444.444458,   77.7777786
    427,   455.555542,   77.7777786
    428,   466.666656,   77.7777786
    429,   477.777771,   77.7777786
    430,   488.888885,   77.7777786
    431,         500.,   77.7777786
    432,   511.111115,   77.7777786
    433,   522.222229,   77.7777786
    434,   533.333313,   77.7777786
    435,   544.444458,   77.7777786
    436,   555.555542,   77.7777786
    437,   566.666687,   77.7777786
    438,   577.777771,   77.7777786
    439,   588.888916,   77.7777786
    440,         600.,   77.7777786
    441,           0.,   88.8888855
    442,   11.1111107,   88.8888855
    443,   22.2222214,   88.8888855
    444,   33.3333321,   88.8888855
    445,   44.4444427,   88.8888855
    446,   55.5555573,   88.8888855
    447,   66.6666641,   88.8888855
    448,   77.7777786,   88.8888855
    449,   88.8888855,   88.8888855
    450,         100.,   88.8888855
    451,   111.111115,   88.8888855
    452,   122.222221,   88.8888855
    453,   133.333328,   88.8888855
    454,   144.444443,   88.8888855
    455,   155.555557,   88.8888855
    456,   166.666672,   88.8888855
    457,   177.777771,   88.8888855
    458,   188.888885,   88.8888855
    459,         200.,   88.8888855
    460,   211.111115,   88.8888855
    461,   222.222229,   88.8888855
    462,   233.333328,   88.8888855
    463,   244.444443,   88.8888855
    464,   255.555557,   88.8888855
    465,   266.666656,   88.8888855
    466,   277.777771,   88.8888855
    467,   288.888885,   88.8888855
    468,         300.,   88.8888855
    469,   311.111115,   88.8888855
    470,   322.222229,   88.8888855
    471,   333.333344,   88.8888855
    472,   344.444458,   88.8888855
    473,   355.555542,   88.8888855
    474,   366.666656,   88.8888855
    475,   377.777771,   88.8888855
    476,   388.888885,   88.8888855
    477,         400.,   88.8888855
    478,   411.111115,   88.8888855
    479,   422.222229,   88.8888855
    480,   433.333344,   88.8888855
    481,   444.444458,   88.8888855
    482,   455.555542,   88.8888855
    483,   466.666656,   88.8888855
    484,   477.777771,   88.8888855
    485,   488.888885,   88.8888855
    486,         500.,   88.8888855
    487,   511.111115,   88.8888855
    488,   522.222229,   88.8888855
    489,   533.333313,   88.8888855
    490,   544.444458,   88.8888855
    491,   555.555542,   88.8888855
    492,   566.666687,   88.8888855
    493,   577.777771,   88.8888855
    494,   588.888916,   88.8888855
    495,         600.,   88.8888855
    496,           0.,         100.
    497,   11.1111107,         100.
    498,   22.2222214,         100.
    499,   33.3333321,         100.
    500,   44.4444427,         100.
    501,   55.5555573,         100.
    502,   66.6666641,         100.
    503,   77.7777786,         100.
    504,   88.8888855,         100.
    505,         100.,         100.
    506,   111.111115,         100.
    507,   122.222221,         100.
    508,   133.333328,         100.
    509,   144.444443,         100.
    510,   155.555557,         100.
    511,   166.666672,         100.
    512,   177.777771,         100.
    513,   188.888885,         100.
    514,         200.,         100.
    515,   211.111115,         100.
    516,   222.222229,         100.
    517,   233.333328,         100.
    518,   244.444443,         100.
    519,   255.555557,         100.
    520,   266.666656,         100.
    521,   277.777771,         100.
    522,   288.888885,         100.
    523,         300.,         100.
    524,   311.111115,         100.
    525,   322.222229,         100.
    526,   333.333344,         100.
    527,   344.444458,         100.
    528,   355.555542,         100.
    529,   366.666656,         100.
    530,   377.777771,         100.
    531,   388.888885,         100.
    532,         400.,         100.
    533,   411.111115,         100.
    534,   422.222229,         100.
    535,   433.333344,         100.
    536,   444.444458,         100.
    537,   455.555542,         100.
    538,   466.666656,         100.
    539,   477.777771,         100.
    540,   488.888885,         100.
    541,         500.,         100.
    542,   511.111115,         100.
    543,   522.222229,         100.
    544,   533.333313,         100.
    545,   544.444458,         100.
    546,   555.555542,         100.
    547,   566.666687,         100.
    548,   577.777771,         100.
    549,   588.888916,         100.
    550,         600.,         100.
*Element, type=CPE4P
  1,   1,   2,  57,  56
  2,   2,   3,  58,  57
  3,   3,   4,  59,  58
  4,   4,   5,  60,  59
  5,   5,   6,  61,  60
  6,   6,   7,  62,  61
  7,   7,   8,  63,  62
  8,   8,   9,  64,  63
  9,   9,  10,  65,  64
 10,  10,  11,  66,  65
 11,  11,  12,  67,  66
 12,  12,  13,  68,  67
 13,  13,  14,  69,  68
 14,  14,  15,  70,  69
 15,  15,  16,  71,  70
 16,  16,  17,  72,  71
 17,  17,  18,  73,  72
 18,  18,  19,  74,  73
 19,  19,  20,  75,  74
 20,  20,  21,  76,  75
 21,  21,  22,  77,  76
 22,  22,  23,  78,  77
 23,  23,  24,  79,  78
 24,  24,  25,  80,  79
 25,  25,  26,  81,  80
 26,  26,  27,  82,  81
 27,  27,  28,  83,  82
 28,  28,  29,  84,  83
 29,  29,  30,  85,  84
 30,  30,  31,  86,  85
 31,  31,  32,  87,  86
 32,  32,  33,  88,  87
 33,  33,  34,  89,  88
 34,  34,  35,  90,  89
 35,  35,  36,  91,  90
 36,  36,  37,  92,  91
 37,  37,  38,  93,  92
 38,  38,  39,  94,  93
 39,  39,  40,  95,  94
 40,  40,  41,  96,  95
 41,  41,  42,  97,  96
 42,  42,  43,  98,  97
 43,  43,  44,  99,  98
 44,  44,  45, 100,  99
 45,  45,  46, 101, 100
 46,  46,  47, 102, 101
 47,  47,  48, 103, 102
 48,  48,  49, 104, 103
 49,  49,  50, 105, 104
 50,  50,  51, 106, 105
 51,  51,  52, 107, 106
 52,  52,  53, 108, 107
 53,  53,  54, 109, 108
 54,  54,  55, 110, 109
 55,  56,  57, 112, 111
 56,  57,  58, 113, 112
 57,  58,  59, 114, 113
 58,  59,  60, 115, 114
 59,  60,  61, 116, 115
 60,  61,  62, 117, 116
 61,  62,  63, 118, 117
 62,  63,  64, 119, 118
 63,  64,  65, 120, 119
 64,  65,  66, 121, 120
 65,  66,  67, 122, 121
 66,  67,  68, 123, 122
 67,  68,  69, 124, 123
 68,  69,  70, 125, 124
 69,  70,  71, 126, 125
 70,  71,  72, 127, 126
 71,  72,  73, 128, 127
 72,  73,  74, 129, 128
 73,  74,  75, 130, 129
 74,  75,  76, 131, 130
 75,  76,  77, 132, 131
 76,  77,  78, 133, 132
 77,  78,  79, 134, 133
 78,  79,  80, 135, 134
 79,  80,  81, 136, 135
 80,  81,  82, 137, 136
 81,  82,  83, 138, 137
 82,  83,  84, 139, 138
 83,  84,  85, 140, 139
 84,  85,  86, 141, 140
 85,  86,  87, 142, 141
 86,  87,  88, 143, 142
 87,  88,  89, 144, 143
 88,  89,  90, 145, 144
 89,  90,  91, 146, 145
 90,  91,  92, 147, 146
 91,  92,  93, 148, 147
 92,  93,  94, 149, 148
 93,  94,  95, 150, 149
 94,  95,  96, 151, 150
 95,  96,  97, 152, 151
 96,  97,  98, 153, 152
 97,  98,  99, 154, 153
 98,  99, 100, 155, 154
 99, 100, 101, 156, 155
100, 101, 102, 157, 156
101, 102, 103, 158, 157
102, 103, 104, 159, 158
103, 104, 105, 160, 159
104, 105, 106, 161, 160
105, 106, 107, 162, 161
106, 107, 108, 163, 162
107, 108, 109, 164, 163
108, 109, 110, 165, 164
109, 111, 112, 167, 166
110, 112, 113, 168, 167
111, 113, 114, 169, 168
112, 114, 115, 170, 169
113, 115, 116, 171, 170
114, 116, 117, 172, 171
115, 117, 118, 173, 172
116, 118, 119, 174, 173
117, 119, 120, 175, 174
118, 120, 121, 176, 175
119, 121, 122, 177, 176
120, 122, 123, 178, 177
121, 123, 124, 179, 178
122, 124, 125, 180, 179
123, 125, 126, 181, 180
124, 126, 127, 182, 181
125, 127, 128, 183, 182
126, 128, 129, 184, 183
127, 129, 130, 185, 184
128, 130, 131, 186, 185
129, 131, 132, 187, 186
130, 132, 133, 188, 187
131, 133, 134, 189, 188
132, 134, 135, 190, 189
133, 135, 136, 191, 190
134, 136, 137, 192, 191
135, 137, 138, 193, 192
136, 138, 139, 194, 193
137, 139, 140, 195, 194
138, 140, 141, 196, 195
139, 141, 142, 197, 196
140, 142, 143, 198, 197
141, 143, 144, 199, 198
142, 144, 145, 200, 199
143, 145, 146, 201, 200
144, 146, 147, 202, 201
145, 147, 148, 203, 202
146, 148, 149, 204, 203
147, 149, 150, 205, 204
148, 150, 151, 206, 205
149, 151, 152, 207, 206
150, 152, 153, 208, 207
151, 153, 154, 209, 208
152, 154, 155, 210, 209
153, 155, 156, 211, 210
154, 156, 157, 212, 211
155, 157, 158, 213, 212
156, 158, 159, 214, 213
157, 159, 160, 215, 214
158, 160, 161, 216, 215
159, 161, 162, 217, 216
160, 162, 163, 218, 217
161, 163, 164, 219, 218
162, 164, 165, 220, 219
163, 166, 167, 222, 221
164, 167, 168, 223, 222
165, 168, 169, 224, 223
166, 169, 170, 225, 224
167, 170, 171, 226, 225
168, 171, 172, 227, 226
169, 172, 173, 228, 227
170, 173, 174, 229, 228
171, 174, 175, 230, 229
172, 175, 176, 231, 230
173, 176, 177, 232, 231
174, 177, 178, 233, 232
175, 178, 179, 234, 233
176, 179, 180, 235, 234
177, 180, 181, 236, 235
178, 181, 182, 237, 236
179, 182, 183, 238, 237
180, 183, 184, 239, 238
181, 184, 185, 240, 239
182, 185, 186, 241, 240
183, 186, 187, 242, 241
184, 187, 188, 243, 242
185, 188, 189, 244, 243
186, 189, 190, 245, 244
187, 190, 191, 246, 245
188, 191, 192, 247, 246
189, 192, 193, 248, 247
190, 193, 194, 249, 248
191, 194, 195, 250, 249
192, 195, 196, 251, 250
193, 196, 197, 252, 251
194, 197, 198, 253, 252
195, 198, 199, 254, 253
196, 199, 200, 255, 254
197, 200, 201, 256, 255
198, 201, 202, 257, 256
199, 202, 203, 258, 257
200, 203, 204, 259, 258
201, 204, 205, 260, 259
202, 205, 206, 261, 260
203, 206, 207, 262, 261
204, 207, 208, 263, 262
205, 208, 209, 264, 263
206, 209, 210, 265, 264
207, 210, 211, 266, 265
208, 211, 212, 267, 266
209, 212, 213, 268, 267
210, 213, 214, 269, 268
211, 214, 215, 270, 269
212, 215, 216, 271, 270
213, 216, 217, 272, 271
214, 217, 218, 273, 272
215, 218, 219, 274, 273
216, 219, 220, 275, 274
217, 221, 222, 277, 276
218, 222, 223, 278, 277
219, 223, 224, 279, 278
220, 224, 225, 280, 279
221, 225, 226, 281, 280
222, 226, 227, 282, 281
223, 227, 228, 283, 282
224, 228, 229, 284, 283
225, 229, 230, 285, 284
226, 230, 231, 286, 285
227, 231, 232, 287, 286
228, 232, 233, 288, 287
229, 233, 234, 289, 288
230, 234, 235, 290, 289
231, 235, 236, 291, 290
232, 236, 237, 292, 291
233, 237, 238, 293, 292
234, 238, 239, 294, 293
235, 239, 240, 295, 294
236, 240, 241, 296, 295
237, 241, 242, 297, 296
238, 242, 243, 298, 297
239, 243, 244, 299, 298
240, 244, 245, 300, 299
241, 245, 246, 301, 300
242, 246, 247, 302, 301
243, 247, 248, 303, 302
244, 248, 249, 304, 303
245, 249, 250, 305, 304
246, 250, 251, 306, 305
247, 251, 252, 307, 306
248, 252, 253, 308, 307
249, 253, 254, 309, 308
250, 254, 255, 310, 309
251, 255, 256, 311, 310
252, 256, 257, 312, 311
253, 257, 258, 313, 312
254, 258, 259, 314, 313
255, 259, 260, 315, 314
256, 260, 261, 316, 315
257, 261, 262, 317, 316
258, 262, 263, 318, 317
259, 263, 264, 319, 318
260, 264, 265, 320, 319
261, 265, 266, 321, 320
262, 266, 267, 322, 321
263, 267, 268, 323, 322
264, 268, 269, 324, 323
265, 269, 270, 325, 324
266, 270, 271, 326, 325
267, 271, 272, 327, 326
268, 272, 273, 328, 327
269, 273, 274, 329, 328
270, 274, 275, 330, 329
271, 276, 277, 332, 331
272, 277, 278, 333, 332
273, 278, 279, 334, 333
274, 279, 280, 335, 334
275, 280, 281, 336, 335
276, 281, 282, 337, 336
277, 282, 283, 338, 337
278, 283, 284, 339, 338
279, 284, 285, 340, 339
280, 285, 286, 341, 340
281, 286, 287, 342, 341
282, 287, 288, 343, 342
283, 288, 289, 344, 343
284, 289, 290, 345, 344
285, 290, 291, 346, 345
286, 291, 292, 347, 346
287, 292, 293, 348, 347
288, 293, 294, 349, 348
289, 294, 295, 350, 349
290, 295, 296, 351, 350
291, 296, 297, 352, 351
292, 297, 298, 353, 352
293, 298, 299, 354, 353
294, 299, 300, 355, 354
295, 300, 301, 356, 355
296, 301, 302, 357, 356
297, 302, 303, 358, 357
298, 303, 304, 359, 358
299, 304, 305, 360, 359
300, 305, 306, 361, 360
301, 306, 307, 362, 361
302, 307, 308, 363, 362
303, 308, 309, 364, 363
304, 309, 310, 365, 364
305, 310, 311, 366, 365
306, 311, 312, 367, 366
307, 312, 313, 368, 367
308, 313, 314, 369, 368
309, 314, 315, 370, 369
310, 315, 316, 371, 370
311, 316, 317, 372, 371
312, 317, 318, 373, 372
313, 318, 319, 374, 373
314, 319, 320, 375, 374
315, 320, 321, 376, 375
316, 321, 322, 377, 376
317, 322, 323, 378, 377
318, 323, 324, 379, 378
319, 324, 325, 380, 379
320, 325, 326, 381, 380
321, 326, 327, 382, 381
322, 327, 328, 383, 382
323, 328, 329, 384, 383
324, 329, 330, 385, 384
325, 331, 332, 387, 386
326, 332, 333, 388, 387
327, 333, 334, 389, 388
328, 334, 335, 390, 389
329, 335, 336, 391, 390
330, 336, 337, 392, 391
331, 337, 338, 393, 392
332, 338, 339, 394, 393
333, 339, 340, 395, 394
334, 340, 341, 396, 395
335, 341, 342, 397, 396
336, 342, 343, 398, 397
337, 343, 344, 399, 398
338, 344, 345, 400, 399
339, 345, 346, 401, 400
340, 346, 347, 402, 401
341, 347, 348, 403, 402
342, 348, 349, 404, 403
343, 349, 350, 405, 404
344, 350, 351, 406, 405
345, 351, 352, 407, 406
346, 352, 353, 408, 407
347, 353, 354, 409, 408
348, 354, 355, 410, 409
349, 355, 356, 411, 410
350, 356, 357, 412, 411
351, 357, 358, 413, 412
352, 358, 359, 414, 413
353, 359, 360, 415, 414
354, 360, 361, 416, 415
355, 361, 362, 417, 416
356, 362, 363, 418, 417
357, 363, 364, 419, 418
358, 364, 365, 420, 419
359, 365, 366, 421, 420
360, 366, 367, 422, 421
361, 367, 368, 423, 422
362, 368, 369, 424, 423
363, 369, 370, 425, 424
364, 370, 371, 426, 425
365, 371, 372, 427, 426
366, 372, 373, 428, 427
367, 373, 374, 429, 428
368, 374, 375, 430, 429
369, 375, 376, 431, 430
370, 376, 377, 432, 431
371, 377, 378, 433, 432
372, 378, 379, 434, 433
373, 379, 380, 435, 434
374, 380, 381, 436, 435
375, 381, 382, 437, 436
376, 382, 383, 438, 437
377, 383, 384, 439, 438
378, 384, 385, 440, 439
379, 386, 387, 442, 441
380, 387, 388, 443, 442
381, 388, 389, 444, 443
382, 389, 390, 445, 444
383, 390, 391, 446, 445
384, 391, 392, 447, 446
385, 392, 393, 448, 447
386, 393, 394, 449, 448
387, 394, 395, 450, 449
388, 395, 396, 451, 450
389, 396, 397, 452, 451
390, 397, 398, 453, 452
391, 398, 399, 454, 453
392, 399, 400, 455, 454
393, 400, 401, 456, 455
394, 401, 402, 457, 456
395, 402, 403, 458, 457
396, 403, 404, 459, 458
397, 404, 405, 460, 459
398, 405, 406, 461, 460
399, 406, 407, 462, 461
400, 407, 408, 463, 462
401, 408, 409, 464, 463
402, 409, 410, 465, 464
403, 410, 411, 466, 465
404, 411, 412, 467, 466
405, 412, 413, 468, 467
406, 413, 414, 469, 468
407, 414, 415, 470, 469
408, 415, 416, 471, 470
409, 416, 417, 472, 471
410, 417, 418, 473, 472
411, 418, 419, 474, 473
412, 419, 420, 475, 474
413, 420, 421, 476, 475
414, 421, 422, 477, 476
415, 422, 423, 478, 477
416, 423, 424, 479, 478
417, 424, 425, 480, 479
418, 425, 426, 481, 480
419, 426, 427, 482, 481
420, 427, 428, 483, 482
421, 428, 429, 484, 483
422, 429, 430, 485, 484
423, 430, 431, 486, 485
424, 431, 432, 487, 486
425, 432, 433, 488, 487
426, 433, 434, 489, 488
427, 434, 435, 490, 489
428, 435, 436, 491, 490
429, 436, 437, 492, 491
430, 437, 438, 493, 492
431, 438, 439, 494, 493
432, 439, 440, 495, 494
433, 441, 442, 497, 496
434, 442, 443, 498, 497
435, 443, 444, 499, 498
436, 444, 445, 500, 499
437, 445, 446, 501, 500
438, 446, 447, 502, 501
439, 447, 448, 503, 502
440, 448, 449, 504, 503
441, 449, 450, 505, 504
442, 450, 451, 506, 505
443, 451, 452, 507, 506
444, 452, 453, 508, 507
445, 453, 454, 509, 508
446, 454, 455, 510, 509
447, 455, 456, 511, 510
448, 456, 457, 512, 511
449, 457, 458, 513, 512
450, 458, 459, 514, 513
451, 459, 460, 515, 514
452, 460, 461, 516, 515
453, 461, 462, 517, 516
454, 462, 463, 518, 517
455, 463, 464, 519, 518
456, 464, 465, 520, 519
457, 465, 466, 521, 520
458, 466, 467, 522, 521
459, 467, 468, 523, 522
460, 468, 469, 524, 523
461, 469, 470, 525, 524
462, 470, 471, 526, 525
463, 471, 472, 527, 526
464, 472, 473, 528, 527
465, 473, 474, 529, 528
466, 474, 475, 530, 529
467, 475, 476, 531, 530
468, 476, 477, 532, 531
469, 477, 478, 533, 532
470, 478, 479, 534, 533
471, 479, 480, 535, 534
472, 480, 481, 536, 535
473, 481, 482, 537, 536
474, 482, 483, 538, 537
475, 483, 484, 539, 538
476, 484, 485, 540, 539
477, 485, 486, 541, 540
478, 486, 487, 542, 541
479, 487, 488, 543, 542
480, 488, 489, 544, 543
481, 489, 490, 545, 544
482, 490, 491, 546, 545
483, 491, 492, 547, 546
484, 492, 493, 548, 547
485, 493, 494, 549, 548
486, 494, 495, 550, 549
*Nset, nset=_PickedSet2, internal, generate
   1,  550,    1
*Elset, elset=_PickedSet2, internal, generate
   1,  486,    1
** Region: (Section-1:Picked)
   1,  486,    1
** Section: Section-1
*Solid Section, elset=_PickedSet2, material=Material-1
1.,
*End Part
** ASSEMBLY
*Assembly, name=Assembly
*Instance, name=Part-1-1, part=Part-1
*End Instance
*Nset, nset=_PickedSet4, internal, instance=Part-1-1, generate
  1,  55,   1
*Elset, elset=_PickedSet4, internal, instance=Part-1-1, generate
  1,  54,   1
*Nset, nset=_PickedSet5, internal, instance=Part-1-1, generate
  55,  550,   55
*Elset, elset=_PickedSet5, internal, instance=Part-1-1, generate
  54,  486,   54
*Nset, nset=_PickedSet6, internal, instance=Part-1-1, generate
   1,  496,   55
*Elset, elset=_PickedSet6, internal, instance=Part-1-1, generate
   1,  433,   54
*Nset, nset=_PickedSet7, internal, instance=Part-1-1, generate
   1,  550,    1
*Elset, elset=_PickedSet7, internal, instance=Part-1-1, generate
   1,  486,    1
*Nset, nset=ALL, instance=Part-1-1, generate
   1,  550,    1
*Elset, elset=ALL, instance=Part-1-1, generate
   1,  486,    1
*Nset, nset=ALLN, instance=Part-1-1, generate
   1,  550,    1
*Elset, elset=ALLN, instance=Part-1-1, generate
   1,  486,    1
*Nset, nset=_PickedSet11, internal, instance=Part-1-1, generate
 496,  550,    1
*Elset, elset=_PickedSet11, internal, instance=Part-1-1, generate
 433,  486,    1
*Nset, nset=_PickedSet11_PP_, internal, instance=Part-1-1, generate
 496,  550,    1
*End Assembly
** MATERIALS
*Material, name=Material-1
*Density
2066.,
*Elastic
 1e+07, 0.28
*Permeability, specific=10000.
 2.4e-06, 0.6
** BOUNDARY CONDITIONS
** Name: BC-1 Type: Displacement/Rotation
*Boundary
_PickedSet4, 1, 1
_PickedSet4, 2, 2
_PickedSet4, 6, 6
** Name: BC-2 Type: Displacement/Rotation
*Boundary
_PickedSet5, 1, 1
** Name: BC-3 Type: Displacement/Rotation
*Boundary
_PickedSet6, 1, 1
_PickedSet6, 2, 2
_PickedSet6, 6, 6
*Initial Condition,Type= Stress, Geostatic
ALL,-1296769,0,0,100, 0.30, 0.30
*Initial Condition,Type=Ratio
ALL,0.3
*Initial Condition, Type=Pore Pressure
ALL,0,100,1000000,0
** STEP: Step-1
*Step, name=Step-1
Geostatic
*Geostatic
** Name: BC-4 Type: Pore pressure
*Boundary
_PickedSet11_PP_, 8, 8
** LOADS
** Name: Load-1   Type: Gravity
*Dload
_PickedSet7, GRAV, 10., 0., -1.
** OUTPUT REQUESTS
*Restart, write, frequency=0
** FIELD OUTPUT: F-Output-1
*Output, field, variable=PRESELECT
** HISTORY OUTPUT: H-Output-1
*Output, history, variable=PRESELECT
*End Step
___________________________________________________________
*Heading
** Job name: FreeAdvancingFront Model name: Model-1
** PARTS
*Part, name=Part-1
*Node
      1,           0.,           0.
      2,         600.,           0.
      3,         600.,         100.
      4,           0.,         100.
      5,   11.1111107,           0.
      6,   22.2222214,           0.
      7,   33.3333321,           0.
      8,   44.4444427,           0.
      9,   55.5555573,           0.
     10,   66.6666641,           0.
     11,   77.7777786,           0.
     12,   88.8888855,           0.
     13,         100.,           0.
     14,   111.111115,           0.
     15,   122.222221,           0.
     16,   133.333328,           0.
     17,   144.444443,           0.
     18,   155.555557,           0.
     19,   166.666672,           0.
     20,   177.777771,           0.
     21,   188.888885,           0.
     22,         200.,           0.
     23,   211.111115,           0.
     24,   222.222229,           0.
     25,   233.333328,           0.
     26,   244.444443,           0.
     27,   255.555557,           0.
     28,   266.666656,           0.
     29,   277.777771,           0.
     30,   288.888885,           0.
     31,         300.,           0.
     32,   311.111115,           0.
     33,   322.222229,           0.
     34,   333.333344,           0.
     35,   344.444458,           0.
     36,   355.555542,           0.
     37,   366.666656,           0.
     38,   377.777771,           0.
     39,   388.888885,           0.
     40,         400.,           0.
     41,   411.111115,           0.
     42,   422.222229,           0.
     43,   433.333344,           0.
     44,   444.444458,           0.
     45,   455.555542,           0.
     46,   466.666656,           0.
     47,   477.777771,           0.
     48,   488.888885,           0.
     49,         500.,           0.
     50,   511.111115,           0.
     51,   522.222229,           0.
     52,   533.333313,           0.
     53,   544.444458,           0.
     54,   555.555542,           0.
     55,   566.666687,           0.
     56,   577.777771,           0.
     57,   588.888916,           0.
     58,         600.,   11.1111107
     59,         600.,   22.2222214
     60,         600.,   33.3333321
     61,         600.,   44.4444427
     62,         600.,   55.5555573
     63,         600.,   66.6666641
     64,         600.,   77.7777786
     65,         600.,   88.8888855
     66,   588.461548,         100.
     67,   576.923096,         100.
     68,   565.384644,         100.
     69,    553.84613,         100.
     70,   542.307678,         100.
     71,   530.769226,         100.
     72,   519.230774,         100.
     73,   507.692322,         100.
     74,   496.153839,         100.
     75,   484.615387,         100.
     76,   473.076935,         100.
     77,   461.538452,         100.
     78,         450.,         100.
     79,   438.461548,         100.
     80,   426.923065,         100.
     81,   415.384613,         100.
     82,   403.846161,         100.
     83,   392.307678,         100.
     84,   380.769226,         100.
     85,   369.230774,         100.
     86,   357.692322,         100.
     87,   346.153839,         100.
     88,   334.615387,         100.
     89,   323.076935,         100.
     90,   311.538452,         100.
     91,         300.,         100.
     92,   288.461548,         100.
     93,   276.923065,         100.
     94,   265.384613,         100.
     95,   253.846161,         100.
     96,   242.307693,         100.
     97,   230.769226,         100.
     98,   219.230774,         100.
     99,   207.692307,         100.
    100,   196.153839,         100.
    101,   184.615387,         100.
    102,    173.07692,         100.
    103,   161.538467,         100.
    104,         150.,         100.
    105,   138.461533,         100.
    106,    126.92308,         100.
    107,   115.384613,         100.
    108,   103.846153,         100.
    109,   92.3076935,         100.
    110,   80.7692337,         100.
    111,   69.2307663,         100.
    112,   57.6923065,         100.
    113,   46.1538467,         100.
    114,   34.6153831,         100.
    115,   23.0769234,         100.
    116,   11.5384617,         100.
    117,           0.,   88.8888855
    118,           0.,   77.7777786
    119,           0.,   66.6666641
    120,           0.,   55.5555573
    121,           0.,   44.4444427
    122,           0.,   33.3333321
    123,           0.,   22.2222214
    124,           0.,   11.1111107
    125,   11.2718477,   89.0921631
    126,   10.8924732,   66.9372559
    127,   45.2704124,   89.1032257
    128,   77.2444153,   10.7467422
    129,   80.3759384,   88.7601089
    130,   110.848495,   10.5819044
    131,   116.395599,   89.2189484
    132,   144.102905,   10.4507618
    133,   151.454102,   89.4722366
    134,   177.328552,   10.4547443
    135,   188.478058,   10.4726534
    136,    197.58815,   89.6588058
    137,   221.700058,   10.6425066
    138,   232.187607,   89.6567688
    139,   255.147934,   10.6664095
    140,   266.749634,     89.65625
    141,   288.646973,   10.6108828
    142,   301.256714,   89.6211395
    143,   312.762756,   89.6560822
    144,   324.250671,   89.6968918
    145,   355.530304,   10.5694904
    146,   358.797363,   89.6434021
    147,   388.971344,   10.5442801
    148,   393.370453,   89.5797043
    149,   422.349091,   10.4520912
    150,   428.092346,   89.4084167
    151,   439.558441,   89.4264755
    152,   455.620483,   10.4068623
    153,   450.954559,   89.4585495
    154,   466.752411,   10.3984337
    155,   462.346985,   89.4704666
    156,   477.848907,   10.3816624
    157,   473.754669,   89.4557114
    158,   488.955414,   10.3396711
    159,    485.24054,   89.3796387
    160,     500.0961,   10.3303881
    161,    496.85788,   89.2404709
    162,   511.290558,   10.3707609
    163,   508.552551,   89.1758118
    164,   522.458069,   10.4434423
    165,   520.237366,   89.4141846
    166,    533.60321,   10.5388155
    167,    531.77594,    89.791214
    168,   544.735657,   10.6344919
    169,   543.200562,   89.9452591
    170,   554.371399,   89.5534592
    171,   565.687927,   89.1940079
    172,   588.975586,   44.3625526
    173,   589.023193,    33.143013
    174,   589.052673,      21.9916
    175,   589.013855,   10.9484921
    176,   566.973267,   10.7341042
    177,    555.87146,   10.7072945
    178,   588.902283,   55.6026535
    179,   588.788147,   66.7682495
    180,   577.128479,   89.0407104
    181,   444.578552,   10.3735228
    182,   433.577271,   10.3686514
    183,   416.484894,   89.5167236
    184,   404.862305,   89.5998688
    185,   411.305939,   10.4544859
    186,   400.234619,   10.4753666
    187,   381.790588,   89.6519852
    188,   370.254913,   89.7017593
    189,   377.901978,   10.5245132
    190,   366.809631,   10.5235367
    191,   347.259155,   89.6983109
    192,   335.699921,   89.7480469
    193,   344.448761,   10.5423679
    194,   333.317627,   10.5511351
    195,   322.146484,   10.5548563
    196,   311.037109,   10.5473013
    197,   299.897552,   10.5562696
    198,   289.722198,   89.6853256
    199,   278.156067,   89.7268906
    200,   277.528046,   10.6024046
    201,   266.430695,   10.6031132
    202,   255.221725,   89.6780548
    203,   243.666168,   89.7066422
    204,   244.055588,   10.6351433
    205,   232.956711,   10.6128092
    206,   220.649475,   89.7029037
    207,   209.086609,   89.7240448
    208,   210.648392,   10.5606699
    209,    199.60199,    10.488102
    210,   186.080902,   89.6379166
    211,   174.535095,   89.5920258
    212,   162.974976,   89.5642624
    213,   166.280853,   10.4127598
    214,   155.220581,    10.409193
    215,   139.828629,   89.4717712
    216,   128.130493,   89.4192123
    217,   133.030624,   10.4925995
    218,   121.957649,   10.5126734
    219,   104.398125,   88.9441452
    220,   92.3644562,   88.7268906
    221,   99.7022095,   10.6458359
    222,   88.4936295,   10.7288227
    223,   68.4524994,   88.9126358
    224,   56.7647514,    89.040184
    225,   66.0441284,   10.4418697
    226,    54.833992,   10.2543621
    227,   33.9156609,   89.1959915
    228,   11.0683613,   78.0642548
    229,   10.8000937,   55.7507896
    230,   44.0022469,   10.5877476
    231,   10.8306465,   44.5221062
    232,    33.087883,   10.9011374
    233,    10.920373,   33.3563728
    234,   22.0513992,   11.0267992
    235,   21.7961578,   67.1463318
    236,   132.755463,   20.8754177
    237,   187.269089,   79.5381317
    238,   277.693054,   20.9429111
    239,   322.492523,   20.8686447
    240,    356.02002,   20.8551941
    241,   389.596436,   20.8176079
    242,   423.054382,    20.659708
    243,   445.193542,   20.5769196
    244,   456.323975,   20.5259438
    245,    467.37442,   20.4515858
    246,   478.400024,   20.3208675
    247,   489.402161,   20.1398659
    248,   500.364288,   20.0351219
    249,   511.326416,   20.1697197
    250,   522.435852,   20.5826302
    251,   532.961243,   80.0959854
    252,   533.550293,    21.008215
    253,   578.112427,   21.7932835
    254,   567.103149,   21.6625977
    255,   555.972595,   21.5510693
    256,    543.80835,   80.5171661
    257,   577.609802,    55.611393
    258,   588.678162,   77.8796387
    259,   440.046265,   79.2123718
    260,   411.972473,   20.7174664
    261,   378.466278,   20.8336105
    262,   344.906555,   20.8440247
    263,   333.757172,   20.8334637
    264,   288.917023,   20.8970642
    265,   267.698273,   79.6116028
    266,   255.213516,   21.0021858
    267,   244.078445,   20.9800949
    268,   221.628784,   20.9875107
    269,   210.532333,   20.9164124
    270,   166.070724,   20.7628193
    271,    143.85791,   20.8065186
    272,   117.341797,   79.0321426
    273,    99.592514,   20.9199295
    274,   44.4599686,   78.3260803
    275,   65.2858124,   20.4001675
    276,   33.2894287,   78.3193512
    277,   44.2307587,   21.3599796
    278,   33.2883072,   22.1141415
    279,   22.0501118,   22.2242336
    280,   22.5837555,   89.1879807
    281,   325.032593,   79.6205139
    282,   451.300476,   79.2152176
    283,   462.583435,     79.18853
    284,   473.900635,   79.1312943
    285,   485.394043,     78.94561
    286,   497.286621,   78.6449585
    287,   509.403778,   78.5701447
    288,   521.487976,   79.2467499
    289,   554.183838,   78.9091949
    290,   544.721802,   21.3482018
    291,   578.057251,   32.9622421
    292,   577.982849,   10.8450756
    293,   577.842102,   44.2776184
    294,    565.55481,   78.0725174
    295,   577.285767,   66.7829666
    296,   577.158447,   77.9187012
    297,   428.522034,   79.3398666
    298,   434.278534,   20.5542698
    299,   416.993469,   79.4471207
    300,    405.39624,   79.5101318
    301,   393.864807,   79.5510101
    302,   400.880249,   20.7385654
    303,   382.317932,   79.6100998
    304,   370.874054,   79.6259308
    305,    359.38327,   79.6317978
    306,   367.336273,   20.8122616
    307,   347.897919,   79.6781311
    308,   336.412903,   79.6938553
    309,   313.552887,   79.6226654
    310,   300.159912,   20.8596096
    311,   311.371063,   20.8464642
    312,   302.028656,   79.6325836
    313,   290.555634,   79.6585541
    314,   279.009033,   79.6797791
    315,   266.565094,   20.9308071
    316,    256.19751,   79.6331635
    317,    244.67659,   79.6380157
    318,   232.941422,   20.9442654
    319,     233.1595,   79.6590958
    320,   221.692352,   79.6874161
    321,   210.168518,   79.6749039
    322,   198.634125,   79.6551361
    323,   199.458466,   20.8341637
    324,   177.184784,   20.7710361
    325,   188.384033,   20.7660046
    326,    175.70607,   79.4729691
    327,   164.180664,    79.404747
    328,   154.993881,   20.7599239
    329,   152.604645,   79.3640518
    330,   140.947479,   79.3732529
    331,   129.196991,   79.3153534
    332,   121.711258,   20.8564663
    333,   110.696518,    20.791975
    334,   92.3624268,   77.7878418
    335,   105.005676,   78.4581604
    336,   79.7713318,   78.1823044
    337,   88.2223587,    21.182745
    338,   76.6117172,   21.3451385
    339,   55.8730469,   78.4078979
    340,   67.6115341,   78.4668045
    341,   54.4065437,   19.8286133
    342,   22.1695118,   78.2331696
    343,   21.6935501,   55.9458199
    344,   21.8658123,   44.6436386
    345,   22.1087971,   33.4262772
    346,   10.9980555,   22.2216225
    347,   416.933441,   69.5995712
    348,   446.363892,   30.5057049
    349,   566.593872,   44.1123848
    350,   551.281616,    66.858696
    351,    428.29715,    69.508934
    352,   435.357147,   30.5460815
    353,   401.816925,     30.82481
    354,   368.134247,   30.8958225
    355,   177.229553,   30.8654556
    356,   92.2158432,   66.4815369
    357,     334.4422,     30.90135
    358,   468.523346,   30.2912636
    359,   532.945557,   31.4093018
    360,   534.732849,   70.8952713
    361,   405.325684,   69.6886063
    362,   370.968658,   69.7795258
    363,   336.712128,   69.7875977
    364,   313.867462,   69.7836456
    365,   290.946259,    69.791748
    366,   255.630966,    31.022543
    367,   256.705658,   69.7788467
    368,   245.206924,   69.8114319
    369,   222.341949,   69.8304672
    370,   165.055756,   69.5663147
    371,   154.855972,   30.9244766
    372,   78.6912003,   68.4636078
    373,    55.268734,    68.135582
    374,    457.54306,   30.3765278
    375,   439.707977,   69.3787231
    376,   450.934296,   69.2834625
    377,   462.183136,   69.2004318
    378,   473.439941,   69.1091995
    379,   485.054688,   68.9361877
    380,   510.269043,   68.1272888
    381,   521.826111,   30.3114738
    382,   566.930908,   32.8073273
    383,   544.252686,   32.0969582
    384,   555.663696,    32.564682
    385,   413.032959,   30.7342415
    386,   379.378021,   30.8807259
    387,   348.039948,   69.8124084
    388,   266.986267,   30.9553261
    389,   44.0359192,   67.6811981
    390,   32.8144455,   56.2651329
    391,   33.3041649,   44.9415092
    392,   479.546539,   29.9894161
    393,   490.294098,   29.6018314
    394,   500.745575,   29.2842999
    395,   497.231232,   68.5039215
    396,   511.129272,   29.3376484
    397,   523.151917,   69.3950653
    398,   543.271179,    73.079483
    399,   565.801758,   55.5381927
    400,    565.08136,   66.7671585
    401,   424.234955,   30.6056213
    402,   393.826385,   69.7398758
    403,   382.271088,   69.7953033
    404,   390.626526,   30.8266411
    405,   359.450867,     69.81073
    406,   356.889404,   30.8848896
    407,   345.697968,    30.874855
    408,   325.189209,   69.8077087
    409,    302.31424,   69.8094025
    410,   311.950958,   30.9182186
    411,   323.216736,   30.8772736
    412,   300.732697,   30.9042835
    413,   289.483917,   30.9046154
    414,    268.12085,   69.7781677
    415,   279.403778,   69.8246155
    416,    278.25415,   30.9036102
    417,   233.662384,   69.8505859
    418,   244.419464,   31.0168419
    419,   233.182312,   31.0066395
    420,   221.920242,   30.9964676
    421,   210.829468,   69.8294754
    422,   188.041672,   69.7014236
    423,    199.32016,    69.814888
    424,   210.720993,    30.975666
    425,   176.470734,   69.6738663
    426,   199.576477,   30.9207745
    427,   188.464935,   30.8476887
    428,   153.475861,   69.5698013
    429,   166.059967,    30.851284
    430,   141.819046,   69.6259689
    431,   143.632294,   30.9830379
    432,    118.32238,   69.3904724
    433,    130.11261,   69.6164627
    434,   132.455063,   30.9940701
    435,   121.409004,   30.8948689
    436,   106.036171,   68.6654053
    437,   110.565529,   30.6313419
    438,   88.5322647,   30.9055634
    439,   99.7528534,   30.4461746
    440,   54.9063339,   27.4560776
    441,    66.803566,   68.6477737
    442,    75.704216,   32.6959114
    443,    63.619751,   29.8206844
    444,   32.9521866,   67.3710709
    445,   47.0622177,   33.5299263
    446,   33.8909492,   33.5469856
    447,   447.766571,   40.2207565
    448,   436.616272,   40.3260078
    449,   313.706573,   60.0626717
    450,   438.894196,   59.6356544
    451,   393.342438,   60.0417442
    452,   402.925354,   40.6358032
    453,   336.452484,   60.0658455
    454,   256.134003,    40.776619
    455,   154.078583,   59.9623795
    456,   458.932068,   40.1237984
    457,   554.900208,   43.7306404
    458,   324.966492,   60.0912132
    459,    55.297718,    58.050621
    460,   470.049561,   40.0281219
    461,   481.087616,   39.7807808
    462,   491.733521,   39.3209457
    463,   538.155029,   62.3898659
    464,   359.177094,   60.0632477
    465,   346.507477,   40.7029953
    466,   302.239288,   60.0793877
    467,   312.670929,   40.7133789
    468,   301.367645,   40.7197609
    469,   267.507263,    40.718441
    470,   222.541473,   60.1154747
    471,   233.525665,   40.8070526
    472,    188.41069,   60.0304832
    473,   199.740402,   40.7642937
    474,   154.715759,   40.7698212
    475,   119.385628,   59.9080505
    476,   120.992508,   40.6526108
    477,   108.083496,   59.1973076
    478,   45.0217972,   45.7911263
    479,   76.7126617,   59.4225998
    480,   543.018738,   42.8120537
    481,   416.267456,   59.8852234
    482,   414.226624,   40.5146027
    483,   245.326309,   60.1065407
    484,   86.0452271,   57.6570091
    485,   427.514526,   59.7967224
    486,   461.330414,   59.4256439
    487,   472.594635,   59.4471397
    488,   531.390564,   41.3898354
    489,   404.719391,   60.0016022
    490,   370.545837,   60.0672607
    491,   347.712616,   60.0888557
    492,   484.146667,   59.3922081
    493,   501.705353,   38.3710976
    494,   510.934601,   57.0621223
    495,   496.306946,   58.9165001
    496,   520.559387,   39.3887672
    497,   510.942017,   37.7754707
    498,   525.487366,   60.1925163
    499,   425.448761,   40.3979988
    500,   380.361206,   40.6894569
    501,   381.833466,   60.0851784
    502,   391.648529,    40.655098
    503,   369.087952,   40.6808624
    504,    357.78833,     40.68787
    505,   335.242004,   40.6927109
    506,   290.833527,   60.0889969
    507,   323.940643,   40.6864929
    508,   290.065765,   40.7087402
    509,    268.15744,   60.0506134
    510,    256.67627,   60.0989609
    511,   279.398834,   60.0998459
    512,   278.789856,    40.689743
    513,   233.810822,   60.1415558
    514,    244.84317,   40.7835999
    515,    222.25238,    40.789711
    516,   211.083679,   60.1299934
    517,   199.644791,   60.1165581
    518,   210.971863,   40.7789574
    519,     165.5466,   59.9688606
    520,   188.557037,    40.705265
    521,   176.908615,   60.0257988
    522,   177.273331,   40.6883163
    523,   166.009079,   40.6935501
    524,   142.456635,   60.0574875
    525,   143.339554,   40.8304367
    526,   130.884384,   60.0660667
    527,   132.070068,   40.7715836
    528,   110.303566,   40.1248817
    529,   98.0004807,   57.3159523
    530,    90.102623,   39.8139381
    531,   100.045937,   39.5499344
    532,   91.2656479,   47.9638138
    533,   75.2399826,   44.7636757
    534,   69.0338974,   41.5182686
    535,   81.1296082,   41.5780258
    536,   66.2530136,   59.2448425
    537,   449.066284,   49.8516273
    538,   369.875305,   50.3827896
    539,   44.2129784,    56.944088
    540,   460.207153,   49.8058167
    541,   335.884094,   50.3984032
    542,   313.233002,   50.4020233
    543,   222.438049,   50.4747086
    544,   245.124741,   50.4649277
    545,   188.509552,   50.4095879
    546,   154.427307,   50.4153519
    547,   120.333939,   50.2338409
    548,   109.607315,   49.5141068
    549,   415.284363,   50.2167702
    550,   59.2158508,   38.4649963
    551,   426.517517,   50.1161308
    552,   471.426971,   49.8168182
    553,   528.762024,   51.0169792
    554,   553.410461,   54.9445992
    555,   510.907135,   44.6173515
    556,   540.897217,   52.9952621
    557,    381.15387,   50.3981895
    558,   358.517303,    50.400341
    559,   301.841919,   50.4209747
    560,   267.873993,   50.4019356
    561,   211.066666,   50.4833641
    562,   131.539825,   50.4247398
    563,   142.919159,   50.4639015
    564,   99.8745422,   48.3599434
    565,   66.6294556,   50.2412338
    566,   403.871277,   50.3285065
    567,   256.437347,   50.4463654
    568,   324.491547,   50.4081917
    569,   279.147034,    50.409729
    570,    75.514122,   51.1762505
    571,   482.692352,     49.74403
    572,   517.729126,   48.1517105
    573,    347.14151,   50.4108925
    574,   493.910553,   49.3023109
    575,   392.502716,   50.3777847
    576,   290.462769,   50.4254723
    577,   233.706268,   50.4843025
    578,   199.726273,   50.4598999
    579,   165.807037,   50.3836555
    580,   83.4995728,   49.5841217
    581,   56.4439964,   48.0636978
    582,   437.761627,   50.0161781
    583,   177.115662,   50.3996582
    584,   11.0438356,   11.0734539
    585,   588.576355,   88.9701767
    586,   450.038757,   59.5478821
    587,   504.437805,   47.5540237
    588,   91.7460709,   54.3675041
  1, 229, 120, 121, 231
  2, 125, 117, 118, 228
  3, 228, 126, 235, 342
  4, 223, 129, 110, 111
  5,  12,  13, 221, 222
  6, 219, 131, 107, 108
  7, 236, 217, 132, 271
  8, 134, 213,  19,  20
  9,  18,  19, 213, 214
 10,  21,  22, 209, 135
 11, 326, 211, 212, 327
 12,  22,  23, 208, 209
 13, 139, 204,  26,  27
 14,  25,  26, 204, 205
 15, 141, 200,  29,  30
 16, 238, 200, 141, 264
 17, 195, 196,  32,  33
 18, 239, 195, 194, 263
 19, 142, 143,  90,  91
 20,  89,  90, 143, 144
 21, 191, 307, 305, 146
 22,  37,  38, 189, 190
 23, 148, 301, 300, 184
 24,  40,  41, 185, 186
 25, 299, 300, 361, 347
 26,  43,  44, 181, 182
 27, 150, 151,  79,  80
 28,  46,  47, 156, 154
 29,  78,  79, 151, 153
 30, 481, 485, 351, 347
 31,  77,  78, 153, 155
 32, 245, 154, 156, 246
 33,  76,  77, 155, 157
 34, 152, 244, 243, 181
 35,  75,  76, 157, 159
 36, 154, 245, 244, 152
 37,  74,  75, 159, 161
 38,  73,  74, 161, 163
 39, 158, 247, 246, 156
 40,  72,  73, 163, 165
 41, 160, 248, 247, 158
 42,  71,  72, 165, 167
 43, 162, 249, 248, 160
 44,  70,  71, 167, 169
 45, 161, 286, 287, 163
 46,  69,  70, 169, 170
 47, 170, 171,  68,  69
 48, 164, 250, 249, 162
 49,  61, 172, 173,  60
 50,  60, 173, 174,  59
 51,  59, 174, 175,  58
 52, 175, 174, 253, 292
 53,  57,   2,  58, 175
 54, 254, 176, 292, 253
 55, 291, 293, 349, 382
 56, 178,  62,  63, 179
 57, 167, 251, 256, 169
 58, 294, 289, 350, 400
 59, 171, 180,  67,  68
 60, 180, 296, 258, 585
 61,   3,  66, 585,  65
 62, 347, 351, 297, 299
 63, 152, 181,  44,  45
 64, 183, 150,  80,  81
 65, 148, 184,  82,  83
 66, 348, 447, 448, 352
 67, 149, 185,  41,  42
 68, 187, 148,  83,  84
 69, 146, 188,  85,  86
 70, 302, 260, 385, 353
 71, 147, 189,  38,  39
 72, 191, 146,  86,  87
 73,  88,  89, 144, 192
 74, 306, 261, 386, 354
 75, 145, 240, 262, 193
 76,  34,  35, 193, 194
 77,  33,  34, 194, 195
 78, 310, 197, 196, 311
 79, 198, 142,  91,  92
 80, 140, 199,  93,  94
 81, 317, 203, 138, 319
 82, 201, 315, 266, 139
 83, 202, 140,  94,  95
 84, 138, 203,  96,  97
 85, 139, 266, 267, 204
 86, 205, 318, 268, 137
 87, 206, 138,  97,  98
 88, 136, 207,  99, 100
 89, 137, 268, 269, 208
 90, 135, 134,  20,  21
 91, 210, 136, 100, 101
 92, 211, 210, 101, 102
 93, 133, 212, 103, 104
 94, 425, 422, 237, 326
 95, 213, 270, 328, 214
 96, 215, 133, 104, 105
 97, 131, 216, 106, 107
 98, 218, 332, 333, 130
 99, 132, 217,  16,  17
100, 108, 109, 220, 219
101, 129, 220, 109, 110
102, 335, 334, 356, 436
103, 130, 221,  13,  14
104, 111, 112, 224, 223
105, 127, 224, 112, 113
106, 127, 227, 276, 274
107, 129, 336, 334, 220
108, 115, 280, 227, 114
109, 117, 125, 116,   4
110, 126, 119, 120, 229
111, 280, 125, 228, 342
112, 231, 121, 122, 233
113,   8,   9, 226, 230
114, 341, 226, 225, 275
115, 230, 232,   7,   8
116, 277, 278, 232, 230
117, 232, 234,   6,   7
118, 278, 279, 234, 232
119,   1,   5, 584, 124
120, 116, 125, 280, 115
121, 119, 126, 228, 118
122,   9,  10, 225, 226
123, 113, 114, 227, 127
124, 128, 225,  10,  11
125,  11,  12, 222, 128
126,  14,  15, 218, 130
127,  17,  18, 214, 132
128, 137, 208,  23,  24
129,  24,  25, 205, 137
130,  27,  28, 201, 139
131,  30,  31, 197, 141
132, 145, 193,  35,  36
133, 408, 364, 449, 458
134,  36,  37, 190, 145
135,  39,  40, 186, 147
136,  42,  43, 182, 149
137, 168, 166,  52,  53
138,  45,  46, 154, 152
139, 151, 259, 282, 153
140,  47,  48, 158, 156
141, 540, 456, 460, 552
142,  48,  49, 160, 158
143,  49,  50, 162, 160
144, 283, 155, 153, 282
145,  50,  51, 164, 162
146, 284, 157, 155, 283
147,  51,  52, 166, 164
148, 285, 159, 157, 284
149, 286, 161, 159, 285
150,  53,  54, 177, 168
151,  62, 178, 172,  61
152,  54,  55, 176, 177
153, 398, 256, 251, 360
154, 292, 176,  55,  56
155,  57, 175, 292,  56
156, 380, 397, 288, 287
157, 179,  63,  64, 258
158, 170, 289, 294, 171
159,  65, 585, 258,  64
160, 295, 179, 258, 296
161,  66,  67, 180, 585
162, 171, 294, 296, 180
163, 299, 183, 184, 300
164, 184, 183,  81,  82
165, 183, 299, 297, 150
166, 402, 403, 501, 451
167, 149, 242, 260, 185
168, 188, 187,  84,  85
169, 187, 303, 301, 148
170, 490, 501, 403, 362
171, 188, 304, 303, 187
172, 147, 241, 261, 189
173, 192, 191,  87,  88
174, 144, 281, 308, 192
175, 538, 503, 500, 557
176, 365, 409, 312, 313
177, 197, 310, 264, 141
178, 195, 239, 311, 196
179, 196, 197,  31,  32
180, 314, 199, 140, 265
181, 199, 198,  92,  93
182, 142, 312, 309, 143
183, 313, 314, 415, 365
184, 200, 238, 315, 201
185,  28,  29, 200, 201
186, 203, 202,  95,  96
187, 368, 367, 316, 317
188, 203, 317, 316, 202
189, 469, 388, 416, 512
190, 207, 206,  98,  99
191, 369, 417, 319, 320
192, 322, 136, 210, 237
193, 320, 321, 421, 369
194, 209, 323, 325, 135
195, 212, 211, 102, 103
196, 327, 212, 133, 329
197, 430, 428, 329, 330
198, 214, 328, 271, 132
199, 216, 215, 105, 106
200, 331, 216, 131, 272
201, 355, 522, 523, 429
202, 217, 236, 332, 218
203,  15,  16, 217, 218
204, 340, 223, 224, 339
205, 356, 334, 336, 372
206, 221, 273, 337, 222
207, 127, 274, 339, 224
208, 338, 442, 443, 275
209, 344, 343, 229, 231
210, 345, 344, 231, 233
211, 233, 122, 123, 346
212, 234, 279, 346, 584
213, 124, 584, 346, 123
214,   5,   6, 234, 584
215, 126, 229, 343, 235
216, 323, 209, 208, 269
217, 237, 210, 211, 326
218, 263, 194, 193, 262
219, 312, 142, 198, 313
220, 240, 145, 190, 306
221, 306, 190, 189, 261
222, 241, 147, 186, 302
223, 302, 186, 185, 260
224, 242, 149, 182, 298
225, 298, 182, 181, 243
226, 244, 245, 358, 374
227, 351, 375, 259, 297
228, 358, 460, 456, 374
229, 376, 377, 283, 282
230, 377, 378, 284, 283
231, 250, 164, 166, 252
232, 378, 379, 285, 284
233, 252, 166, 168, 290
234, 290, 168, 177, 255
235, 252, 359, 381, 250
236, 251, 167, 165, 288
237, 288, 165, 163, 287
238, 177, 176, 254, 255
239, 174, 173, 291, 253
240, 257, 293, 172, 178
241, 253, 291, 382, 254
242, 290, 383, 359, 252
243, 178, 179, 295, 257
244, 256, 289, 170, 169
245, 349, 457, 384, 382
246, 259, 151, 150, 297
247, 143, 309, 281, 144
248, 265, 140, 202, 316
249, 238, 264, 413, 416
250, 204, 267, 318, 205
251, 206, 320, 319, 138
252, 270, 213, 134, 324
253, 324, 134, 135, 325
254, 272, 131, 219, 335
255, 335, 219, 220, 334
256, 273, 221, 130, 333
257, 276, 444, 389, 274
258, 275, 225, 128, 338
259, 338, 128, 222, 337
260, 227, 280, 342, 276
261, 390, 343, 344, 391
262, 539, 389, 444, 390
263, 230, 226, 341, 277
264, 233, 346, 279, 345
265, 393, 392, 246, 247
266, 456, 540, 537, 447
267, 392, 461, 460, 358
268, 393, 462, 461, 392
269, 379, 395, 286, 285
270, 396, 394, 248, 249
271, 397, 380, 494, 498
272, 293, 291, 173, 172
273, 457, 554, 556, 480
274, 400, 350, 554, 399
275, 400, 399, 257, 295
276, 352, 401, 242, 298
277, 403, 402, 301, 303
278, 304, 188, 146, 305
279, 405, 387, 491, 464
280, 353, 404, 241, 302
281, 305, 307, 387, 405
282, 307, 191, 192, 308
283, 354, 406, 240, 306
284, 573, 465, 504, 558
285, 364, 408, 281, 309
286, 313, 198, 199, 314
287, 466, 449, 364, 409
288, 568, 507, 505, 541
289, 357, 411, 239, 263
290, 410, 467, 468, 412
291, 412, 413, 264, 310
292, 367, 414, 265, 316
293, 314, 265, 414, 415
294, 388, 469, 454, 366
295, 320, 206, 207, 321
296, 543, 515, 471, 577
297, 366, 418, 267, 266
298, 321, 207, 136, 322
299, 544, 514, 454, 567
300, 419, 420, 268, 318
301, 422, 423, 322, 237
302, 325, 323, 426, 427
303, 521, 519, 579, 583
304, 420, 424, 269, 268
305, 370, 425, 326, 327
306, 420, 515, 518, 424
307, 424, 426, 323, 269
308, 329, 133, 215, 330
309, 330, 215, 216, 331
310, 563, 546, 455, 524
311, 355, 429, 270, 324
312, 431, 525, 527, 434
313, 371, 431, 271, 328
314, 548, 547, 475, 477
315, 431, 434, 236, 271
316, 432, 433, 331, 272
317, 564, 548, 477, 529
318, 336, 129, 223, 340
319, 434, 435, 332, 236
320, 439, 438, 337, 273
321, 437, 439, 273, 333
322, 340, 339, 373, 441
323, 539, 478, 581, 459
324, 438, 442, 338, 337
325, 438, 530, 535, 442
326, 342, 235, 444, 276
327, 277, 341, 440, 445
328, 279, 278, 446, 345
329, 348, 352, 298, 243
330, 243, 244, 374, 348
331, 457, 480, 383, 384
332, 254, 382, 384, 255
333, 257, 399, 349, 293
334, 289, 256, 398, 350
335, 485, 551, 582, 450
336, 551, 499, 448, 582
337, 362, 403, 303, 304
338, 363, 387, 307, 308
339, 324, 325, 427, 355
340, 435, 437, 333, 332
341, 263, 262, 407, 357
342, 245, 246, 392, 358
343, 375, 376, 282, 259
344, 383, 290, 255, 384
345, 251, 288, 397, 360
346, 300, 301, 402, 361
347, 304, 305, 405, 362
348, 308, 281, 408, 363
349, 309, 312, 409, 364
350, 410, 412, 310, 311
351, 266, 315, 388, 366
352, 317, 319, 417, 368
353, 470, 513, 417, 369
354, 418, 419, 318, 267
355, 327, 329, 428, 370
356, 328, 270, 429, 371
357, 479, 372, 441, 536
358, 373, 339, 274, 389
359, 344, 345, 446, 391
360, 550, 445, 440, 443
361, 551, 485, 481, 549
362, 376, 586, 486, 377
363, 393, 247, 248, 394
364, 396, 249, 250, 381
365, 287, 286, 395, 380
366, 349, 399, 554, 457
367, 401, 385, 260, 242
368, 451, 489, 361, 402
369, 404, 386, 261, 241
370, 464, 490, 362, 405
371, 453, 491, 387, 363
372, 315, 238, 416, 388
373, 235, 343, 390, 444
374, 389, 539, 459, 373
375, 487, 552, 571, 492
376, 394, 493, 462, 393
377, 496, 497, 396, 381
378, 379, 492, 495, 395
379, 488, 496, 381, 359
380, 555, 572, 494, 587
381, 553, 556, 463, 498
382, 400, 295, 296, 294
383, 554, 350, 463, 556
384, 352, 448, 499, 401
385, 575, 502, 452, 566
386, 464, 558, 538, 490
387, 353, 452, 502, 404
388, 386, 500, 503, 354
389, 262, 240, 406, 407
390, 503, 538, 558, 504
391, 541, 505, 465, 573
392, 466, 559, 542, 449
393, 411, 410, 311, 239
394, 357, 505, 507, 411
395, 412, 468, 508, 413
396, 569, 512, 508, 576
397, 510, 509, 414, 367
398, 509, 511, 415, 414
399, 513, 483, 368, 417
400, 366, 454, 514, 418
401, 419, 471, 515, 420
402, 561, 518, 515, 543
403, 321, 322, 423, 421
404, 472, 517, 423, 422
405, 517, 516, 421, 423
406, 455, 519, 370, 428
407, 426, 473, 520, 427
408, 425, 370, 519, 521
409, 427, 520, 522, 355
410, 330, 331, 433, 430
411, 475, 526, 433, 432
412, 371, 474, 525, 431
413, 272, 335, 436, 432
414, 527, 525, 563, 562
415, 562, 563, 524, 526
416, 435, 476, 528, 437
417, 580, 532, 588, 484
418, 439, 531, 530, 438
419, 437, 528, 531, 439
420, 529, 356, 484, 588
421, 336, 340, 441, 372
422, 536, 459, 581, 565
423, 275, 443, 440, 341
424, 479, 536, 565, 570
425, 581, 550, 534, 565
426, 442, 535, 533, 534
427, 373, 459, 536, 441
428, 446, 445, 478, 391
429, 278, 277, 445, 446
430, 447, 348, 374, 456
431, 482, 549, 566, 452
432, 407, 465, 505, 357
433, 376, 375, 450, 586
434, 375, 351, 485, 450
435, 549, 482, 499, 551
436, 452, 353, 385, 482
437, 482, 385, 401, 499
438, 458, 453, 363, 408
439, 469, 560, 567, 454
440, 428, 430, 524, 455
441, 360, 397, 498, 463
442, 507, 568, 542, 467
443, 478, 539, 390, 391
444, 486, 540, 552, 487
445, 377, 486, 487, 378
446, 378, 487, 492, 379
447, 480, 488, 359, 383
448, 572, 553, 498, 494
449, 463, 350, 398, 360
450, 465, 407, 406, 504
451, 504, 406, 354, 503
452, 409, 365, 506, 466
453, 467, 542, 559, 468
454, 467, 410, 411, 507
455, 560, 569, 511, 509
456, 512, 416, 413, 508
457, 483, 510, 367, 368
458, 369, 421, 516, 470
459, 471, 419, 418, 514
460, 422, 425, 521, 472
461, 473, 426, 424, 518
462, 474, 371, 429, 523
463, 432, 436, 477, 475
464, 476, 435, 434, 527
465, 356, 529, 477, 436
466, 443, 442, 534, 550
467, 372, 479, 484, 356
468, 556, 553, 488, 480
469, 347, 361, 489, 481
470, 533, 570, 565, 534
471, 586, 537, 540, 486
472, 461, 571, 552, 460
473, 566, 489, 451, 575
474, 491, 573, 558, 464
475, 462, 574, 571, 461
476, 394, 396, 497, 493
477, 495, 494, 380, 395
478, 492, 571, 574, 495
479, 488, 553, 572, 496
480, 555, 587, 493, 497
481, 493, 587, 574, 462
482, 496, 572, 555, 497
483, 500, 386, 404, 502
484, 501, 557, 575, 451
485, 453, 541, 573, 491
486, 458, 568, 541, 453
487, 365, 415, 511, 506
488, 468, 559, 576, 508
489, 544, 567, 510, 483
490, 567, 560, 509, 510
491, 569, 576, 506, 511
492, 512, 569, 560, 469
493, 543, 577, 513, 470
494, 577, 471, 514, 544
495, 561, 543, 470, 516
496, 517, 472, 545, 578
497, 518, 561, 578, 473
498, 579, 523, 522, 583
499, 520, 545, 583, 522
500, 473, 578, 545, 520
501, 546, 579, 519, 455
502, 523, 579, 546, 474
503, 430, 433, 526, 524
504, 474, 546, 563, 525
505, 562, 547, 476, 527
506, 528, 476, 547, 548
507, 531, 528, 548, 564
508, 532, 564, 529, 588
509, 535, 580, 570, 533
510, 564, 532, 530, 531
511, 484, 479, 570, 580
512, 557, 500, 502, 575
513, 568, 458, 449, 542
514, 559, 466, 506, 576
515, 483, 513, 577, 544
516, 472, 521, 583, 545
517, 549, 481, 489, 566
518, 478, 445, 550, 581
519, 582, 448, 447, 537
520, 557, 501, 490, 538
521, 516, 517, 578, 561
522, 526, 475, 547, 562
523, 580, 535, 530, 532
524, 450, 582, 537, 586
525, 587, 494, 495, 574
   1,  588,    1
   1,  525,    1
   1,  525,    1
1.,
*End Part
** ASSEMBLY
*End Instance
  1,  2,  5,  6,  7,  8,  9, 10, 11, 12, 13, 14, 15, 16, 17, 18
 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34
 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50
 51, 52, 53, 54, 55, 56, 57
   5,   8,   9,  10,  12,  13,  14,  15,  17,  22,  24,  26,  28,  53,  63,  67
  71,  76,  77,  90,  99, 103, 113, 115, 117, 119, 122, 124, 125, 126, 127, 128
 129, 130, 131, 132, 134, 135, 136, 137, 138, 140, 142, 143, 145, 147, 150, 152
 154, 155, 179, 185, 203, 214
  2,  3, 58, 59, 60, 61, 62, 63, 64, 65
  49,  50,  51,  53,  56,  61, 151, 157, 159
   1,   4, 117, 118, 119, 120, 121, 122, 123, 124
   1,   2, 109, 110, 112, 119, 121, 211, 213
   1,  588,    1
   1,  525,    1
   1,  588,    1
   1,  525,    1
   1,  588,    1
   1,  525,    1
   3,   4,  66,  67,  68,  69,  70,  71,  72,  73,  74,  75,  76,  77,  78,  79
  80,  81,  82,  83,  84,  85,  86,  87,  88,  89,  90,  91,  92,  93,  94,  95
  96,  97,  98,  99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111
 112, 113, 114, 115, 116
   4,   6,  19,  20,  27,  29,  31,  33,  35,  37,  38,  40,  42,  44,  46,  47
  59,  61,  64,  65,  68,  69,  72,  73,  79,  80,  83,  84,  87,  88,  91,  92
  93,  96,  97, 100, 101, 104, 105, 108, 109, 120, 123, 161, 164, 168, 173, 181
 186, 190, 195, 199
*End Assembly
** MATERIALS
*Density
2066.,
*Elastic
 1e+07, 0.28
 2.4e-06, 0.6
*Boundary
_PickedSet4, 1, 1
_PickedSet4, 2, 2
_PickedSet4, 6, 6
*Boundary
_PickedSet5, 1, 1
*Boundary
_PickedSet6, 1, 1
_PickedSet6, 2, 2
_PickedSet6, 6, 6
ALL,0.3
ALL,0,100,1000000,0
** STEP: Step-1
*Step, name=Step-1
Geostatic
*Geostatic
*Boundary
** LOADS
*Dload
** OUTPUT REQUESTS
*End Step
RE: Huge Difference Between Free Meshing (AdvancingFront) and Structu
Please, DO NOT cut&paste the whole input file in the post.
1.As you can see the post is cut after a certain number of lines.
2.If you want to share the .inp files with people potentially interested you can pack them in an archive and upload it to a file sharing web-site, then post only the link.
1. My guess without looking at input files is that your mesh was not refined enough regardless the meshing technique you used.
2. Since the mesh was not identical, technically you cannot compare the strains at same integration points.
xerf
Thank you for your reply  . About 2. "upload it to a file sharing web-site, then post only the link" I never done that before. If you have a moment please teach me
-Anyway as I said refining is not a reason for this discrepancy I ultimately refine both and found the difference (almost three order) didnot change.
AM not comparing a spicific point to a specific point but I am looking at the average results obtained from both >
Anyhow if you are a member in Yahoo ABAQUS group. Today I posted the same question over there under " On Meshin Technique" and both input files are there plesae look at them and you see what I am talking about
The meshing technique will have no effect on the results as the input file doesn't know which technqiue was used to generate the mesh. As xerf says it must be the mesh refinement or some other error in the input.
corus
Helppoorpeople,
Be nice to know which elements you used - element choice and formulation would have a significant effect on the results aswell.
Also, like Xerf says, it's not a good idea to post entire input decks.  There are sites like http://www.yousendit.com that are ideal for remotely hosting files for sharing.
Martin
Dear martin and Corus
Please note that although both meshes have  the same type and very much almost the same Number of elements and look even topogically the same, how the Advancing Free mesh leads to much higher displacement (three order almost) and resultes in localized  displacement (strain) response while structural gives uniform
http://download.yousendit.com/E97E1EC942616B17
P.S :I put both input files for this very simple model in one file as the site doesnot allow me to upload more than one file at a time.
