Protect block attributes
Can I protect block attributes in AutocAD ?
Thanks in advance.
RE: Protect block attributes
what do you mean by "protect"??
sorry, I didn't explain it well...
What I ment was: can I make the command ATTEDIT not functional for one block ?
I want the block to have attributes, but I don't want other people to change them...
Maybe XREF to protected dwg instead of block.
No other way to protect a block within an unprotected dwg.
Ok, I'll try it.
But, if I protect the dwg with XREF, I can't also change the attributes, isn't it ?
thanks again...
