SP 3.0 cannot see origin in sketch
When I activate a sketch in a plane, I cannot see the red origin!!! Anyone else has this problem?
Mechanical Engineer
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: SP 3.0 cannot see origin in sketch
SW07-SP3
Gerald
SW07-SP3
Heckler
Sr. Mechanical Engineer
SWx 2007 SP 3.0 & Pro/E 2001
XP Pro SP2.0 P4 3.6 GHz, 1GB RAM
NVIDIA Quadro FX 1400
o
_`\(,_
(_)/ (_)
(In reference to David Beckham) "He can't kick with his left foot, he can't tackle, he can't head the ball and he doesn't score many goals. Apart from that, he's all right." -- George Best
Also please re-read thread559-181693 especially my last post.
The red sketch origin has never been selectable. It is the underlying main origin which is being selected.
SP3 did not change any settings of my SW install. It may have in yours. All you need do is hide the main origin in the FM tree and select origins in the View drop-down. Do that and save the templates for both part and assemblies and you will have what you want.
SW07-SP3
Gerald
Jason
UG NX2.02.2 on Win2000 SP3
UG NX4.01.0 on Win2000 SP3
SolidWorks 2007 SP2.2 on WinXP SP2
B. Long
P 4 2.80 GHz
2.5 Gig Ram
Solidworks Office 2007 Sp. 2.2
For those who use the red origin to define the basic sketch, this change is quite frustrating. I hope they will fix it in the next SP!!
I will not upgrade the computers at work from 2.2 to 3.0 until they fix it!!!
Mechanical Engineer
I did search. However, if you notice those threads did not answer the question...Thanks!
Mechanical Engineer
Hi Gerald,
To recap our conversation:
Before SP3- with View>Origins off, you could still see the red sketch origin in a new sketch, but not the blue model origins.
After SP3- with View>Origins off, you now can't see the sketch origin. Turning origins on shows the red origin, but also all blue origins in the sketch. To get a clean view, each blue origin needs to be individually hidden.
It looks like this has been reported under SPR 364822, and I will submit a request to have you added to the list for this issue.
You didn't ask for an answer! You asked has anyone else seen this problem.
Heckler
o
_`\(,_
(_)/ (_)
