REACTION FORCE AT NOZZLE END DUE TO BACK PRESSURE
Can somebody help me to find
1) The magnitude of force along discharge(nozzle)pipe axis due to back pressure (assuming the valve is closed in the pipeline).
Pump Details :
Discahrge Pipe ID : 35.00 inches
Operating Pressure : 300 Psi
Distance between valve & nozzle end is 150.00 inches along the nozzle axis.
Thanks in advance..
Arline
Pump Details :
Thanks in advance..
Arline
RE: REACTION FORCE AT NOZZLE END DUE TO BACK PRESSURE
If the valve is close and there's no flow won't this be a static problem and you just need to multiply the area of the pipe by the system pressure to get the axial force or am I missing something.
regards
desertfox
BigInch
-born in the trenches.
http://virtualpipeline.spaces.msn.com
Now i am convinced from your replies that the calculation is okay.
Thank your very much for your quick response.
Arline
Using the discharge ID and 300psi I get 288633.825lbf
desertfox
