Assembly problem
Assembly problem
Hi all
My bus model is so completed so i divided it into four parts for many people solve it to save my time, but problem is that after finishing fours part, i realize that i can not assembly all of together. Please tell me what should be done in this case to save all the thing i have done in each parts and assembly it together ?
Phanhung
Phanhung
RE: Assembly problem
corus
Four parts of my bus is two sides left and right, up and down floor. Each parts include many components (it is a car frame with thousand of components). For eacg parts i have done many things, such as partition, tie, coupling, mesh. I can not merge the model because each component in each part is different shape ans size so i have to design different properties for each one. I also can not assembly the parts separately because if i do in this way, i have to do again all the things i have done for each parts (partition, tie, coupling). So pls help me for some suggestions in this case.
Phanhung
Interaction>create Constraint>Tie
and use the surface to surface method.
However, the tie surface should be away from the area of intresed.
