Shot Peening Prior to Carburizing
Anyone have any data indicating the impact of trying to carburize the surface of a 9310 material which has been shot peened PRIOR to carburizing? i.e does shot peened surface act as a mask? Is diffusion process impacted by high residual compressive stresses?
Any input would be welcomed. Thanks!
RE: Shot Peening Prior to Carburizing
rmw
If you are asking about reprocess, then the "dimpling" has little effect, since the shot peen was on a very hard surface, and there is very little textural change.
There is concern, although I have seen no studies, that shot peening can "mask". I do not see a reason to suspect this, as previous posters state, the sp stress is removed upon heating.
My 2 cents.
