A335 for superheater coils
Is it permitted to construct the superheater coils with SA-335 P22 instead of SA-213 T22, according to ASME Section 1?
The reason for that is only availability.
Thanks a lot
regards
Thanks a lot
regards
fabio vincent
www.figener.com.br
RE: A335 for superheater coils
From a material standpoint, there is no problem because both material specifications are endorsed by ASME B&PV Code (Section I). The pipe specification will have additional requirements embedded for fabrication because pipe is primarily used external to the boiler for conveying fluids, whereas, tubing is used in heat transfer applications in the boiler setting.
ASME SA 335 is a material specification for seamless pipe, while SA 213 T22 material specification is for tubing in boilers and heat exchangers. I would suggest you carefully review both specifications and compare pipe versus tube tolerances in your application.
fabio vincent
www.figener.com.br
fabio vincent
www.figener.com.br
