Analyzing Potential Overpressuring by a Pump
I've been asked to review if a particular pump can overpressure a piping system. The piping system is 300# class and the pumps are centrifugal type pumping anhydrous ammonia. What are the different things I need to look at? Is it just shut-off head? Or do I have to look at the pump curve.
New to pumps here, thanks for the help.
RE: Analyzing Potential Overpressuring by a Pump
Johnny Pellin
The suction is coming from a tank, so I can get that information pretty easily. I do not have a pump curve on the pump. All I have at this moment is the shut-off head (someone told me). Thanks again.
BigInch
-born in the trenches.
http://virtualpipeline.spaces.msn.com
Note that if your facility falls under OSHA PSM requirements, you must have this information to document that this calculation (blocked-in) was checked against the PSV sizing.
I'm not a real engineer, but I play one on T.V.
A.J. Gest, York Int./JCI
