How to Rotate Scan input IGES Curves in SolidWorks
We are working on a Reverse Engineeing Project. The Scan Input we have obtained is tilted above the base plane for 2 Deg.
we want to rotate the all Scan input curves to match the base plane which will help us to proceed with the project.
Murugan.s
Murugan.s
RE: How to Rotate Scan input IGES Curves in SolidWorks
Maybe one way is to insert into a new assy, mate the part how you like to a plane, then save as a part.
Chris
SolidWorks 07 3.0/PDMWorks 07
AutoCAD 06
ctopher's home (updated 03-13-07)
regards,
Murugan.S
