Changing the origin of the model
I want to select a new origin to my model so that when I go Query- Node -
I get the coordinate of this Node in terms of this new origin. Any help please
RE: Changing the origin of the model
Select User Specified, and then you should be able to pick any user-defined coordinate system for output.
You can create coordinate systems in "Tools > Coordinate System > Create"
Martin
I want to chamge it in CAE (Assemply . Part . Property..Step Muduli ) because In Keyword Edit I am establishing Initial Conditions for the model Sets and it is easier if I do so in terms of an origin the elevations in terms of which are readily availble to me
In assembly> translate instance> Select the part you want to move, then follow its instruction.
