Routing, Electrical
Routing, Electrical
Hello, I am wondering if someone knows the answer to this. I am new to the Routing feature and am trying it out. I am wondering if it is possible to have more than 1 wire under a clip. The routing feature seems to be working great but the only thing is, is that I'll route all my wires first and assign the AWG, Color, Diameter, etc... And that looks fine and perfect, just how I want them. This is when it starts acting weird. My next step I do is reroute the spline through my clips. Now the first one I do looks great. It keeps the all the route properties and everything such as color, AWG, etc... But when I go and reroute the next wire in the clip along with the other wire thats when it gets weird. It loses the color of the wire. And then if you go and try to select chain, it only selects the spline up to the clip. And not the whole wire like it should. I don't know if I'm doing something wrong or skipping a step or what. Maybe one of you guys may be able to help me out.
smiley1570
smiley1570
RE: Routing, Electrical
SW07-SP3
smiley1570
Did you purchase SolidWorks Premium to get Router?
Yes you can have more than one wire under clip. Although your solid model will look like one wire.
Bradley
SolidWorks Professional x64 2007 SP3.0
Intel(R) Pentium(R) D CPU
3.00 GHz, 3.93 GB of RAM
Virtual memory 12577 MB
NVIDIA Quadro FX 3400
smiley1570
I do not know for sure about the location of the clip. I only saw the demo. We are thinking about upgrading for the same reason as you.
See if you can see this webcast from GoEngineer on SolidWorks Routing.
http://66.89.101.227/web6/tips.html
Bradley
Scott Baugh, CSWP![[pc2] pc2](https://www.tipmaster.com/images/pc2.gif)
www.scottjbaugh.com
FAQ731-376
