Involute Spline
Involute Spline
What's the major differences between involute spline angle 30deg, 37.5deg and 45deg PA in terms of torque capacity, ease of installation, fit, etc.
Also what is the playing role of Number of teeth in the above selection. What i am trying to figure out is I have a 1.69" shaft that need involute spline but don't know which type to choose.
Thanks in advance
Kflee0
Thanks in advance
Kflee0
RE: Involute Spline
37.5 an 45 degrees PA splines are used usually if manufactured by rolling.
If you'll cut the spline, select standard dia pitch (module) 30 degree spline.
